1000 masking layers
Texas_Signmaker
Very Active Signmaker
I'm trying to import a land plat into Flexi and there is a making layer for EACH letter. 1000 masks. Is there away to break all that out using Flexi or Illustrator all at once?
2B
are you looking to edit in Flexi or just print?
Do not have / use Flexi, but when we have issues with layers and our RIP program, we use a different format.
can you export as a flattened PDF or a PNG?
bannertime
Should be an unmask all on the right click in flexi. Same with Illustrator, somewhere in the menu you can select>all clipping mask>unmask all or something. Flexi will likely create a big black box, or a bunch of that you'd need to delete. Illustrator will create a bunch of blank path layers.
Texas_Signmaker
Where is unmask all in Flexi? I only see "Unmask"
Texas_Signmaker
No, I don't want to flatten it.
Boudica
I've dealt with the lovely 10,000 layers of a plat map - I feel for you. I wasn't trying to do anything in flexi though - I was cleaning it up in Illustrator. It took for ever. I realize this isn't helpful - Just wanted to share that I know your pain :mad:
bannertime
Sorry, I just got back here. Attached is a screenshot. Next step is deciphering which path to keep and which to delete.
I'm assuming that it's a bunch of gradients or something behind all the mask. Which will be a nightmare. Best bet is doing it in Illustrator or whatever native program they used and exporting it properly.
Evan Gillette
Like bannertime said, right click unmask all, then use select by attributes ( shortcut is "d") to selct the black rectangles and delete...its not going to be fun but cross your fingers and hope it works
