4x6 sign, pricing
Kysparky
4x6 sign (painted MDO) double sided 2 color small frame around sign, supported on 4x4 post. I have cost figured but wanted to see if I am in the ballpark.:thankyou: Any thoughts would be appriciated. There is nothing fancy about this one.
SignProOhio
If the background is white and you're putting a frame around it (edge cap?) I would use Finish Board....It's already finished on both sides...just cut and glue on your edge caps....i'd at least fill and prime the edges to seal them in case the edge cap leaks. Would save a lot of time.
WOODBS
what are you finishing the edges with , i have seen mdo with no sealant look good for a long time??
Kysparky
Will be using white primer and paint. I am also considering using aluminum panel instead. Probably an 0.40 I don't think the cost difference will be much either way
Kysparky
Right now I have this one figured at around 465.00 including install. Materials approx. 100.00. I think I'm gonna be up against Signs Now but I really think there is no comparison between what they are pricing and what I am pricing.
OldPaint
$450-480 JUST FOR THE SIGN & BOARD. 4x8 painted mdo is now $100. you gota buy a 4x8 to get a 4x6!!!!!!!!!!!!!
buildin frame and painitn it in its self is $200-300!!!!
yea give it away....they will luv ya....
today i sold a 2 sided 4x6 on alumicore $300. a 3x6 single sided alumicore for $180, 2x3 on alumicore $40. NO INSTALL, NO FRAME!!!!!!!
Jillbeans
Ok first of all...you are planning on using just that type of support system for heavy MDO? After the first good storm you'll be back fixing it.
I would suggest using Alumalite...much lighter but not flimsy like .040. I would even be leery of hanging that onto that frame without some sort of better framing, something to keep it from swinging.
http://www.signcraftersupply.com/product_cat2.asp?ProdCat1=Brackets+Hardware&ProdCat2=Bracket
There are some good brackets here. Good, helpful people if you ever call there.
Price-wise, for that layout on Alumalite, 2-sided, I would be at $375-$400.
Uninstalled but trimmed with edge cap.
(I just did a single-sided simple 4x8 yesterday in Alumalite/cut vynull with edge caps for $450 for an existing client for the Farm Show)
If using MDO, white, get the factory-finished stuff from your supplier as SignPro suggested. It's about the same price as Alumalite. Finish the edges with 2 coats of Tite-Bond II wood glue and 1-Shot, (fill any voids with putty and sand off first) and cap off with the edge trim...it comes in ½" as well as the thinner stuff and is made by Laminators Inc. Silicone it on.
Woodbs, I have never seen unsealed MDO hold up very well at all.
Love....Jill
PS
OP, last month I sold a fancy painted/vynulled MDO d/s 2'x3' for $250.
Richard Flint
A 4' x 6' MDO sign is much too heavy to be supported the way you've shown. I would suggest using (2) 4'' x 4"s.
SignProOhio
If she uses 6x6 posts it should hold up....4x4 will not be enough to support that weight.....4x4 in that configuration can hold a 2x3 sign or something around that size....Unless you're planning on using 4x4 steel posts.
Kysparky
If my fingers only knew where the keys were on this keyboard I would be fine. The sign itself is 4' x 3". That cuts the weight in half. I think the 0.40 would work pretty good being that small. 1/2" MDO won't be bad either. Sounds like I'm not really to far off in my pricing here. Thanks for all the help on this one.
bob
I assume you still suffer some keyboard disorientation and meant to type 4'x3'. On that assumption the sign alone would be ~$360 on Alumalite. Since I loathe MDO and all but absolutely refuse to use it.
I have no idea what the posts and installation might cost. I don't do that either. I do signs, not construction, there are others that do that sort of thing. But I do know that 4x4's in this configuration are marginal. A 3'+ cantilever using a 4x4 puts the 'M' into marginal.
Billct2
I would not use .040, too flimsy unless you frame it or fold the edges.
Alumalite or alumaply would be great, just use good hangers. I would still consider changing the install to between two posts. If they insist on a post and arm I would build it with a 4"x6" for the upright and 4"x4" for the arm with additional bracing. If you do a post & arm don't try to keep the sign from swinging, a post & arm sign is meant to swing.
Flame
I'd charge even more than that. I'm at $300 for a SINGLE sided 3x6.
4x6, I'd prefer to use alumilite myself. But either way I'd be looking at $450-$500 plus install. So maybe $600?
OldPaint
i dont know where you get youre engineering info from....
but in my years ive installed a lot of 4X8 3/4" MDO signs....on 4x4's!!!!!! so 6x6 is a WASTE OF MONEY!!!!
