gromitron
Hello folks, I have a Roland Versacamm vs 640 for print cut and I have a job coming up that requires unprinted vinyl cutting with avery a5 vinyl. It's a big job long term, enough to warrant buying a new cut only machine, if it would significantly speed up the process. The Versacamm seems rather slow, so I wanted to get advice on what machine you might recommend for quality fast cutting of simple small graphics (most rolls I use would only require 24 inch). Other than roland I am unfamiliar with most of the other brands... Their pro cutter 36 is about 3 times the speed of the VS64, but any advice for others to look at would be most appreciated.
Sorry if this is in the wrong forum!!
Ed
Ed
