alt key
mountainmang
i saw an old post by fred about using the alt key for characters...ie alt 0146 for an apostrophe. is there a reference chart for those type of entries? thanks :thumb:
bob
It's merely the decimal value of the character with a leading zero. There's a plethora of ASCII* equivalence charts, just do a search for 'ASCII'. Be sure and select one that's decimal and not octal or hexadecimal. You can tell if it's decimal if some character has a digit in its equivalence code that's greater than 7 and not an alpha A-F. In other words if the characters proceed 0,1,2,3,4,5,6,7,10,11... it's octal. If they proceed 0,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11... it's hexadecimal.
*ASCII==American Standard Code for Information Interchange. As opposed to, say, EBCDIC which is Extended Binary Coded Decimal Interchange Code.
weaselboogie
http://www.starr.net/is/type/altnum.htm
Alt key + Four digits
¤ Alt+0164
† Alt+0134
× Alt+0215
÷ Alt+0247
‡ Alt+0135
± Alt+0177
— Alt+0151
– Alt+0150
¶ Alt+0182
§ Alt+0167
ˆ Alt+0136
˜ Alt+0152
« Alt+0171
» Alt+0187
¦ Alt+0166
‰ Alt+0137
© Alt+0169
® Alt+0174
™ Alt+0153
á Alt+0225
à Alt+0224
â Alt+0226
ä Alt+0228
å Alt+0229
Á Alt+0193
à Alt+0195
Ä Alt+0196
Å Alt+0197
À Alt+0192
 Alt+0194
æ Alt+0230
Æ Alt+0198
ç Alt+0231
Ç Alt+0199
ê Alt+0234
é Alt+0233
ë Alt+0235
è Alt+0232
Ê Alt+0202
Ë Alt+0203
É Alt+0201
È Alt+0200
ï Alt+0239
í Alt+0237
î Alt+0238
ì Alt+0236
Í Alt+0205
Ì Alt+0204
Î Alt+0206
Ï Alt+0207
ñ Alt+0241
Ñ Alt+0209
œ Alt+0156
Œ Alt+0140 ô Alt+0244
ö Alt+0246
ò Alt+0242
õ Alt+0245
ó Alt+0243
ø Alt+0248
Ó Alt+0211
Ô Alt+0212
Õ Alt+0213
Ø Alt+0216
Ö Alt+0214
Ò Alt+0210
š Alt+0154
Š Alt+0138
ú Alt+0250
ü Alt+0252
û Alt+0251
ù Alt+0249
Ù Alt+0217
Ú Alt+0218
Ü Alt+0220
Û Alt+0219
ÿ Alt+0255
Ÿ Alt+0159
ý Alt+0253
Ý Alt+0221
ž Alt+0158
Ž Alt+0142 ª Alt+0170
Þ Alt+0222
þ Alt+0254
ƒ Alt+0131
ß Alt+0223
µ Alt+0181
Ð Alt+0208
° Alt+0176
º Alt+0186
• Alt+0149
„ Alt+0132
… Alt+0133
¬ Alt+0172
¿ Alt+0191
¡ Alt+0161
¥ Alt+0165
£ Alt+0163
€ Alt+0128
¢ Alt+0162
¹ Alt+0185
² Alt+0178
³ Alt+0179
½ Alt+0189
¼ Alt+0188
¾ Alt+0190
Alt key + Three digits
128 Ç
129 ü
130 é
131 â
132 ä
133 à
134 å
135 ç
136 ê
137 ë
138 è
139 ï
140 î
141 ì
142 Ä
143 Å
144 É
145 æ
146 Æ
147 ô
148 ö
149 ò
150 û
(Greek letters and
math symbols are
between 224 and 247)
151 ù
152 ÿ
153 Ö
154 Ü
160 á
161 í
162 ó
163 ú
164 ñ
165 Ñ
167 º
168 ¿
248 °
250 · (smaller bullet)
Capital Signs
WOW.:notworthy::clapping::corndog::goodpost:
rcook99
Hey WB can I just have the part of your BRAIN that can remember all of those combinations? Pleeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeease!!!
:clapping::clapping:
Fred Weiss
You can also just go to
Start > All Programs > Accessories > System Tools > Character Map
and it displays the character set for every font installed on your computer.
thewood
While typing in Flexi, you can select "insert symbols" and display all the available characters for any font.
I use Alt+0129 quite a bit (bullet).
Sign_Boy
That's funny right there
I can't find that, looked but it's not there?
Fred Weiss
The name of the program is charmap.exe. You can either do a search or just enter it in the Run command.
On my computer it is located at %SystemRoot%\system32\charmap.exe
Sign_Boy
Thank you Fred, tried that it's not there odd
Ahh just found it, I had to do a search for it.
Thank you Fred:thumb:
I have done a search for the vector doctors post and can't locate it. Can someone point me in the right direction. Thanks Charlotte
