Aluma-corr, how do you cut it?
L Town Graphics
Just curious as to what the pros use to cut it with when you don't need to use a full piece? I have a layout that it being finalized in the next few days and want to make sure I get it done the right way the first time.
tsgstl
panel saw and trim cap it
and if your blade is crappy enough it will grab on to the trim real nicelike
wes70
Skillsaw with 60 tooth carbide blade, depth set just enough to cut through and a straight edge...cuts so clean you wont need to file!
Jillbeans
I order it cut from either of my suppliers for a fee of about $7.
They also sell end-caps in case I end up cutting it myself with my trusty circular saw/straight edge/clamp method.
Love....Jill
bob
Treat it as if it were merely a sheet of plywood of the same thickness and you'll be fine.
Anything that saws wood will saw aluminum laminates. The finish of the cut with any given blade will be pretty much as rough or as smooth as that same cut would have been in wood. Table saws, band saws, circular saws, jig saws, scroll saws, et al will all cut the material.
S'N'S
I use a electric hand saw with a 100t carbide blade made for cutting aluminum and straight edge.
I've used it on 3mm sheet aluminum, 4mm probond, etc and cuts it beautifully.
wes70
:thumb:
