Ken, no worries on the "worms"... your mention was entirely innocent... although it opened the doors... if I had to trace the uglyness to a source, I wouldn't go to my client, myself, or your comment. I'm not sure where I would go though... it just sort of snowballed the further downhill it went...
...anyway, I plan to use
sign gold on the lettering. The gold colored panel is more gold then I think I should use, so that might even change somewhat. On a job like this I will charge enough that I will do a full size trial run on an 18" x 24" aluminum panel that ends up in my sample collection, but also gives the best opportunity for a last minute change based on the appearance. The base may very well be printed, but there will probably be some other cut vinyl layers also.
Rick, thanks for your observations. Believe it or not, I've only seen one or two jobs on this island with prismatic letters that I didn't do. We are behind the times, so I will most likely tire of it as well... but I'm ok with it, & still have a ways to go before I learn to make best use of it, but I try to limit it's use to appropriate clients.
On the other comments, I think I will go back into it & cut the large panel, lower the bottom half & allow a wider semi-circle panel for Trucking. First I might kern "Eagle Wings" to leave a tad more space at each end... then with the resized "Trucking" panel, I can bring the point size up to (or closer to) the size of "Eagle Wings" ...this should also use up that extra space in front & in back of trucking for a better fit all around. Thanks for that suggestion.
As for a better integration with the Eagle, it wasn't bothering me any more then the Canadian Goose was in the source design I drew from... but now I wonder what might help that. What bothers me is the empty talons & I think it bothers the client a little bit. Do you think a bit of a horizon line that the Eagle is perched on, that dissappears at each end of the striped section would help?
