Anybody having problems with 3m IJ40 C
ericm
Had three rolls of IJ 40 C delivered started printing and color and overall print quality really bad!
Loaded 35c and printed same file and profile with excellent results
WYLDGFI
We use quite a bit of 40C. Haven't seen anything like that yet. Have any pics of the printed area flat on a table? Maybe another area or 2 of the same roll/sheet.
Joe House
Try cleaning off an area with Isopropyl to see if it's old vinyl with plasticizer migration.
I would also clean off the encoder strip, because that was my first thought before you told me that other media works fine. Are you using different presets on the different materials?
Good Luck
WYLDGFI
That area right there looks like its a mechanical issue...misalignment somewhere along the print.
SpeedproHFX
Is the vinyl flat? We've been having a few issues with backer paper of certain brands rippling/almost tunneling
in humidity, especially near the start of a roll. While it doesn't quite head strike, it gets a bit wonky where it bumps...?
ericm
Printed on hp570 here is another shot! Did An alignment ,checked all status plots only happens on IJ 40
running 180 and all is good
greysquirrel
I think you have a profile issue....see what is different between the 3m profile and the 180 profile...look at optimizer, vacuum settings.
ericm
Doing the tests i use the same profile printing on 40 C 35C and 180 C I even built a profile specifically for that roll still have the same issue
I’ve only had this problem once before last year IJ 35C was having an issue...... having some more material dropped off tomorrow from a different lot number so we’ll see what happens
WYLDGFI
Wow....thats somewhat surprising to me. Glad to hear its worked out for you though. Good news.
