Anyone have a door measurement for this template?
Stacey K
I like making signs
Yes - I measured the door on the truck but I resized my photo and threw out the sheet of paper I had it written on (ughhh). It's a 45-minute drive one way so just trying to save another trip. I can't find a one-off template to purchase.
ProSignTN
Just so you can double check
guillermo
I have done a simple task and it has worked for me all the time..... since I watched a movie.
I will place something that I know what size it is, for example, a credit card, a 6" squeegee or bigger, or the one that works the best, a ruler, tape to the door and take a picture, then I import that into my illustrator app and enlarge it to the size of the ruler. you will be off about .25" to .5". Hope this helps if you call your customer.
myront
Dammit, make it faster!!
we always pull in the template and then scale it up to mock up the graphics full size.
Same here. I have a macro for corel to scale the template. Yes, easy enough to just type in 2000% but I can right-click and run the macro. I also have another that I can draw a rectangle over an area of known distance i.e. door width, then scale the rectangle to that measurement, shift select the image, run the macro. Scales the photo to match.
myront
With illustrator, draw a rectangle over a known measurement i.e. door width, change the size to the real world size with proportion locked, now add the image to your selection, run a "Scale Photo" script. User will be prompted to choose either w or h, hit ok, image is sized accordingly and rectangle is deleted.
MrDav3C
This second macro sounds like it could save me time scaling photos manually, is it something you created or purchased?
