That was just a screenshot of a template from ProOutlines not the actual templateIt says its 1/20 scale, scale it up
Same here. I have a macro for corel to scale the template. Yes, easy enough to just type in 2000% but I can right-click and run the macro. I also have another that I can draw a rectangle over an area of known distance i.e. door width, then scale the rectangle to that measurement, shift select the image, run the macro. Scales the photo to match.we always pull in the template and then scale it up to mock up the graphics full size.
With illustrator, draw a rectangle over a known measurement i.e. door width, change the size to the real world size with proportion locked, now add the image to your selection, run a "Scale Photo" script. User will be prompted to choose either w or h, hit ok, image is sized accordingly and rectangle is deleted.I have done a simple task and it has worked for me all the time..... since I watched a movie.
I will place something that I know what size it is, for example, a credit card, a 6" squeegee or bigger, or the one that works the best, a ruler, tape to the door and take a picture, then I import that into my illustrator app and enlarge it to the size of the ruler. you will be off about .25" to .5". Hope this helps if you call your customer.
I created with a little helpThis second macro sounds like it could save me time scaling photos manually, is it something you created or purchased?
Straight and level is becoming an expert skill only mastered by sign shop ownersWhat I do…
I have many 1in. x 12in. Magnetic material strips with a red stripe on it.
I put it on the door or panel.
Take a high res pic on my phone and import the pic into the software and scale it according.
Make sure the pic is straight on level and not skewed at an angle. Works great.
No fumbling for misplaced paper or measurements.
I have a 4 door pickup and have one mag in every door jam so I don’t leave one at home.
If you end up in a pinch or the customer is far away have the tape a 8.5x11in pc of paper on the door and send you a straight on level pic.
I think it's time for me to start doing that again...I like this idea of having several!What I do…
Same, but mine is a 12x12" square magnet. If it's a fiber glass door I tape it on . Customers like to put a tape measure up to part of the vehicle, and snap a picture but I usually can't tell what part it is. LolWhat I do…
