Anyone know of a good masking vinyl that uses transfer tape?
appstro
Anyone know of a good masking vinyl that uses transfer tape? I tried oracal 810 with rtape and the transfer tape is too strong. I need to be able to use transfer tape and apply the vinyl then remove the transfer tape to reveal the mask. The details on the mask are very small and thin. Regular vinyl sticks to the work surface too hard and the masking vinyl sticks to the transfer tape! I cant win! Any ideas here??
MikePro
Pask Mask from Fellers, use it all the time without issue using Rtape transfer tape. Even the low tack stuff sticks.
Mosh
I use medium tack transfer-rite tape on some pretty detailed stencils....TIP:AFTER you apply the graphic/stencil, and BEFORE you pull the tape off spray the tape with rapid-tac and rub the tape, it will loosen the tape's hold on the vinyl, then slowly peel it back on itself.
fresh
We use R-tape's paint mask with R-tape application tape (high tack!) and we don't have any problems. We go through a LOT of paint mask.
TammieH
I am pretty sure all manufacturers have a Paint Mask vinyl, 3M, Avery, FDC, for sure, and Oracal Has a stencil film.
Never had any problem using transfer tape on a Paint Mask.
