Back lit Re-face only and phone number change
S
scarface
Guest
Hey, I have a repeat customer (that actually pays and doesn't complain :thumb:) needing some signs re-faced for his new business.
He has a 3x6' back lit sign which he is taking the old vinyl off and he needs BARBER SHOP put on in one line in a nice blue with a blue barber's pole with red stripes on the side (1 side only)
He also needs a phone number change on a aluminum sign which is 6"x54" in white.
I'm using my graphixcalc software and coming up a bit high IMO. He said if the prices aren't bad he will do them now, if they are higher than he's wanting (didn't say a budget) he will have to hold off for a while.
3x6' vinyl cut only $185
6x54" phone number vinyl cut only $31
$306 Installed for both with 1.5hr install @ $60/hr rate
Also Could i use just regular cast vinyl for this since i don't do many back lit projects?
Thanks!
cgsigns_jamie
You'll want to use a cast TRANSLUCENT vinyl for the back lit sign. I use 3M 3630 Series, I think Fellers sells it by the yard if you only need a small amount.
Using Blue 3M 3630 with red accent on barber pole I'd be at $322 + Install for the 6' x 3'
S
scarface
Guest
What i quoted in the first price to everyone was cast regular vinyl. Is there anyway i can use it, i mean of course it will go on but how's it going to look?
I don't think the customer will be able to afford trans vinyl right now by the talk of him. Trans is crazy expensive, a 24x10yd roll is like $115
S
scarface
Guest
Alright, I looked and Fellers has the 8500 Oracal for only $75.50
Looking at about $100 in materials with 1 yard of red for the small stripes and a 24x10yd roll of blue
$245 vinyl only
$31 vinyl only
$366 Installed both
S
scarface
Guest
I think i'm going to use just the trans vinyl since it's the correct way to do the back lit job ya know?
Looking forward to hearing everyone elses pricing on this job so i can see where i'm at.
Thanks!
If you don't use translucents, then I would tell him you don't have the right materials for the backlit portion.
The phone portion is about $40, so you're right on with that.
The backlit portion sounds to be around $200 or so.
Installation would be around $125.
Those are very conservative numbers. We'd be around $525 to $575, based on the difficulty of the copy with weeding and such.
You really can't charge a customer for a full roll of vinyl... just because you don't stock it. If you'd mark it up and be fair about it, you'll have plenty for the next one that comes in. Unless you can totally hide the cost of materials in large projects... I'm afraid you'll scare people off because you're essentially asking them to not only pay for their own needs, but to buy your inventory for you. That isn't fair, but then.... you have to do what you have to do.
S
scarface
Guest
I added up your prices and it's $365 installed. I'm confused where your coming up with $525-575 Gino?
Thanks for giving me some guidance on this job. I simply put the measurements and all into my software and those are the prices it was giving me. I was just calculating the raw mats for this job at around $100 but as i said i just put the pricing and all in the program and these are the given prices.
For my install I'm figuring 1.5 hrs which is $90 with my $60/hr shop rate currently.
Thanks!
