banner over an oven? hot question!
PrintQueen
Hey y'all. We just got a job in for our campus dining department. they've got an area above a small oven where they would like to hang a banner. They are asking if a vinyl banner is a good option - it will only be up for about 2 months. I've uploaded their mockup for reference to oven and location (plz ignore the cheezy graphic puns).
looking for opinions or recommendations. we use a latex printer and our two banner vinyls that we have on hand are 13oz Duratex or 18oz Ultraflex. Both look like they passed NFPA 701-TM2, and the ultraflex looks like it also passed CA Title 19. They asked for 13oz, but I'm leaning toward the 18oz.. but wanted to get a 2nd opinion.
thanks!
:flamey:
RaymondLoewy
Pretty fly for a Sign Guy
I would pull the spec sheet for the material you are considering and see what kind heat/flammability rating it has.
PrintQueen
i took a look at them but i honestly don't know how to read through this stuff. figured i'd see if anyone here had any expertise.
i've attached the info I was able to pull.. it's all confusing to me. :covereyes:
  • Duratex 13oz Scrim Banner FR.pdf
  • ultraflex fr.pdf
eahicks
In my experience, all the heat from an oven is inside the oven. This is a non-issue.
Billct2
It's hot around ovens and if it was a permanent sign I'd say use aluminum.
Not just for safety but also cleanliness, it's gets real dirty greasy around cooking.
But since it's temp I'd be Ok with a banner but I'd hang it a little higher
PrintQueen
i agree with the aluminum. i was going to recommend something like that but i know that they'll say that they only want something temporary, which is why they were learning toward the banner. I think i'll have them go with the 18oz vs the 13oz, and I'll recommend that they hang it a little higher. thanks for your input, I appreciate your feedback!
eahicks
Sure it can be hot around ovens. It's also hot as balls outside, and I don't see any banners melting or bursting in to flames. But go with what you feel I say.
One thing to consider........ if this is temporary, how do you intend to hang it and how will you patch the holes (or recommend to them) how to patch the holes when they're done with the banner ??
Billct2
Drop ceiling so ceiling clips with wire or jack chain and I'd use pole pockets with a piece of pvc pipe top & bottom
jochwat
Graphics Department
Looks like a job tailor-made for removable wall vinyl (e.g. Briteline's Rad Grafix 6 mil removable and repositionable PVC wall graphic vinyl). As long as any heat from the oven that rises to the vinyl isn't over 200 degrees F, it's all good.
Greg Kelm
www.cheetaprint.com
I agree. If it put out any kind of substantial heat, it wouldn't be on a counter close to the wall. If temporary, use 3m command hooks to hang or even colored thumbtacks it that's drywall.
RaymondLoewy
You might consider selling them on aluminum by telling them you may be able to clean and reface the front side and if not apply a print to the back side and provide longer service of what your are selling them will knowing if they do, they will come back to pay you more.
Just my opinion. Let me know what happens, I like to see how projects wind up after people post asking for ideas.
