Basic Coro Signs, Price Help
S
scarface
Guest
Hey guys, I have a lady needing just 5 18x24" basic coro signs done. Black lettering on white coro.
Now i haven't used my new printer for coro signs yet and from doing the math, it would be alittle cheaper and easier on myself. I'm thinking print them on 3651 unlaminated and leave about 1/8" smaller than the coro, and mount them up rather than doing cut vinyl.
She needs these to be double sided and just have:
Childcare
Phone Number
License #
I have done some market research and the going rate is around $18-22 double sided around here for low amounts. For 1 sided I'm seeing around $5 psf which would be $15.
I'm thinking $24 double sided for these, Think that is a fair price? At $120 for the entire job that will leave me with 1.5 hrs to complete this at $60 hr ($90)
I'll have around $30.00 into the ink, 3651 (unlaminated) and coro. The stakes I'll add on a buck or so to the final price.
Thanks everyone!
luggnut
i get around that price for one color 2 sided at that quantity... i have printed them with no lam and they stuck together.. i guess they need more than one day to dry or maybe it won't work.. i don't know.
so now for low quantities i used cut vinyl or charge enough to laminate.
S
scarface
Guest
What you mean stuck together? Should just be able to use my big squeegee and start about a inch onto the coro and swipe them like nothing.
The prices above seem low but that's what people are getting around here for some reason.
FatCat
Scar, I have also found they can stick (when stacked together) under the right conditions. It takes a while for the solvent to completely outgas and until it does it is active. Also, if you don't let them dry long enough, you'll see stretching in the inked areas when trying to apply them with your BS. Best bet is let them dry for several hours before trying to apply without lam.
threads1
For only 5, I would be a couple bucks more but, I think your in the ball-park. I would print them ( I would use GCVP ) and use your big squeegee. Be done in 20 min.
maddmd
Print them all the time, but not with 3651 use LG stuff from harbor, print same profile, cheaper and mounts perfect with BS :thumb:
gnatt66
ya, i'd print them and use 3164, as long as they arent full bleed you can mount them in 10 minutes if need be. same for 3165ra but coros dont usually warrant better vinyl.
and i'd be more like 26-30ea double sided..
acothran
We just made a few yard signs with IJ35C and attempted to do so unlaminated. Maybe it's just our shop, but thinner unlaminated vinyl is a pain to work with. After fighting a few, we ended up with transfer tape on the last ones just to make it easier. It was much easier but that adds more material costs and labor. I think IJ35 is around 3.2 mil and 3651 is even thinner at 2.5 mil. We had to knock out a handful on Friday and ended up laminating them just to save installation time (install was with a standard 4" or 6" squeegee). It comes down to cost of lamination vs. cost of more labor.
I want to try gnatt66's idea of using 3164 (4.0 mil thick) or another thicker, economy vinyl which should be easier to handle than some of the thinner ones. Maybe we just haven't learned the proper technique but if you've never put unlaminated vinyl (especially thinner media) on coro, I would recommend trying one (even non-printed) before printing them all. Maybe some others here have some good ideas on installing nonlaminated vinyl on coro.
As for price, the market here is around the $20-$25 range for something like that at that qty.
Allen
luggnut
i let them dry overnight and they still stuck together... don't know how long it takes to fully cure? but your customer is gonna take them and stack them on top of each other.... so it makes me nervous that thay will stick together. 2 sided i would use cut vinyl or charge enough to laminate.
Even if you stack screen printed signs on top of each other... they will stick together. It's a chemical reaction of some sort. I'm not sure at all if this is accurate, but what has been my rule is nothing gets stacked unless you sheet it.... meaning you put a non-stick piece of paper between each and every one of your signs.... or suffer the consequences.
However, we generally print them and just laminate them on…. whether by our laminator or a Big Squeegee and then rack them or strand them on end, for a day or so.
We also charge for that extra material cost and labor, but then, we never have the problem and let the customer know this about our shop. This is another reason why people will use us over our competition…. because most people don’t want to spend the extra buck to do something right and just go in with the attitude, well, I’ll save 65 cents and can still undercut the other guy.
I just got a deposit on an order on Thursday for 50pcs. 18” x 24” 2-sided black on white with step stakes and we’re getting $14.85 each. We’re now debating printing or screening.
Anyway, for 4 or 5 signs, we’d be around $45.00 each.
Farmboy
I've said this before and will say it again. Get some pricing software! Something you can put YOUR numbers into. Not everyone else's. Yes, I know right now your struggling for work and every dollar is gold, but how are you going to know what you NEED to make if you don't figure it out for YOU! EstiMate
gnatt66
Maybe we just haven't learned the proper technique but if you've never put unlaminated vinyl (especially thinner media) on coro, I would recommend trying one (even non-printed) before printing them all. Maybe some others here have some good ideas on installing nonlaminated vinyl on coro,
Allen
if you have a Big Squeegee it's a snap!...peel back the first inch of the print, fold back, cut off a short strip off the backer, line up and take your Big Squeegee (i have the cradle tool) and drag it over the strip to stick that down...
then simply fold it over the cradle and push!...takes all of 30 seconds to apply each one, untaped..no bubbles.
works with thinner vinyl too, just gotta wait longer before applying.
S
scarface
Guest
I do have pricing software but you have to do what your market will bare. I'm not going to charge $50 for the exact same sign if all the reputable shops near me is going to charge $25 and we all use the same supplier (we do really)
I use graphix calc but wanted to see what everyones opinions was...
TheSnowman
I print them on 3621, unlaminated. I make them 1" smaller all the way around, then I have 1/2" edges for lining it up fast, and then just big squeegee them down. I do try and let them dry for at least a day if not longer when I know about the job with enough time. Far as cost...I'd be $25/ea.
ONLINE SIGN GUY
Ussualy if its a simple 1-2 color design thats mainly lettering like this sounds, we do cut vinyl...maybee im nuts, but the most we will do this way is about a dozan, after that we switch to screen printing or digital.
Maybee Im crazy but it seems for this application cut vinyl is the way to go, unless your printing on big sheet of coro then cutting down like a few people suggested.
we sell 1-2 color cut vinyl 18 x 24" fdouble sided for 25.00 here but where lifting prices to 30.00.
S
scarface
Guest
Thanks everybody, Hopefully she goes through with the order. Printing seems the way to go
