Best Rip for large files
JAKES GARAGE
We are currently using Flexi 7.6 and are looking to upgrade or get a new Rip that will work with wraps on semi's. When we output a file in photoshop that's larger than 30k pixels it turns into a psb and Flexi will not open it. I normally layout the files @100 percent size and 72 to 100 dpi since the designs have a lot of images/text due to being mainly for motorsports . Any input would be great.
Thanks JT
SignBurst PCs
Simply output it from Photoshop as a .tiff and Flexi should be able to handle it.
I like slicing the image into panels in Photoshop as well, that way you end up doing the heavy lifting on your design software instead of the RIP software. But that is just personal preference.
FatCat
Usually I design box truck/semi trailers at 25% or 50% and then just use the RIP to enlarge it to full size. I'm using Wasatch, but I'm sure Flexi should do this as well.
MikePro
since upgrading to Onyx x10, i've been blowing through large rips in no time.... i used to have to wait hours for some projects, and now its ripped in minutes!
SightLine
It's only a limit for Photoshops psd file type. Many other file types also impose this limit. Tiff images do not and for native photshop files psb does not impose that limit. Just do exactly as signburst said - prior to final output just flatten the file and save it out as a tiff and Flexi deals with it just fine.
signswi
There actually is a .tif filesize limit (note: filesize, not pixel count as .psd limits) but you can overcome it by enabling ZIP compression in the .tif save dialog. I was able to generate, rip (onyx) and print one .tif that wrapped three walls of a restaurant at 150dpi (photographs, couldn't go vector) this way. Make sure to embed the ICC profile.
