I wanted to chime in with a little more questions on this matter if possible.
Several of the solutions mentioned above in this I have had a little practice testing out, being Acronis True Image and Norton Ghost.  Most of my experience is with a version of Ghost, though unfortunately I don't know the exact version.  While working with the Engineering department at the University of Kansas we had used Ghost for imaging mass numbers of computers in several different labs.  It was amazingly smooth and I wish I could replicate this type of setup for myself for other business as well.  A server was set up as the Ghost image host, where we could remote login, set up a Ghost session selecting the image file and the number of client computers that would be loading that image.  Then we just pop in a boot disk to each of the computers, type the IP address of the Ghost server in, and let it start loading the image.  Amazingly smooth and efficient.
Now, most of the problem I have run into in the past is several of the more well-known imaging tools requires that you have the software INSTALLED on the
computer even to restore an image.  This means that in a situation where you are putting in a fresh unformatted drive to recover after a complete crash or similar, you still would have to install
Windows and install the software to be able to recognize the image files and run the software to restore that image to the drive.
My question then, with all of your experience, what other software out there could I create an image of a drive, and not have to follow through this whole process of reinstalling
Windows and the software in the situation of recovering the image if an entire new drive or a blank drive were used?
Is there software that will allow me to just create a sort of boot disk and select the image file and run directly off a bootable disk?  I've seen several use an imaging tool, such as is available on the SystemRescueCD linux live CD, and create an image in a separate partition on the same original hard drive for recovery (like many HP and
Dell systems come set up now) but if you would have actual drive failure and need to replace the drive you would also lose your image in that situation.
