Hi.  I've had a Roland VersaCAMM for a few years now and I'm stuck trying to figure out how to fix this print problem.
My black has been printing a bit fuzzy for a few months and this month is it really bad.
I've attached some images of my print quality.
A few days ago I did 2 manual cleans, each one followed by a powerful clean. No luck.
I even held a swab of solution up to the head for several minutes. No luck. Cleaned the encoder strip with alcohol and a lint free cloth. No luck.
The following day I poured some solution in the captops and let it sit a bit in solvent ( although I think it soaked down through the captop after a minute or so ). Then I repeated the swab manual clean, followed by 2 powerful cleans. Then I printed several test prints, blocks of black text and black squares. No results. I repeated the swab maual clean and 2 more powerful cleans. No luck. Same streaky black prints.
Had a tech come over and he replaced the captops, swab cleaned & powerful cleaned, and installed a nice little copper static garland in the back to reduce static buildup as he thought it may be a static issue. After he left I printed some more black squares and text as well as a print test. No luck. Same blurry black prints. He told me to lower the heat when printing, but I've noticed no difference.
My Cyan prints fine. Just the black prints blurry and on some thin media it prints with strong stripes in it. Banner print *ok* with just hint of fuzzy edge.
Any ideas? I want to work on this before calling the tech again. He said it is not a head issue as I've not printed enough material to wear out the head.
