Need Help (BN20) replacement Dampers? or Printhead?
Heeya
hello
I would like to get some advice. I originally used BN-20 (printer A) to run a small business. However, one day, blue ink started to seep into the yellow ink area as shown in the photo below, and the resulting color came out messy. (The photo shows a nozzle test after cleaning, so the invaded area is relatively small, but as I print the image, the blue ink gradually invades the yellow area.)
So I bought the same BN-20 (printer B) used a few month ago, but when I came home and did a nozzle test, the black nozzle was messy, as shown in the second photo. When I print images, the area around the black area is messy. (The seller said that he sold it after the test print, so he is not responsible for it.)
I already spent a lot of money on a second printer, so calling a Roland technician is burdensome. What is the best way to solve this situation?
Should I buy a new damper for printer A and replace it?
Or can I put the printer head of A into printer B?
Can I print in CMY-ink only without black ink on printer B?
Or the other ideas?
I will wait for your wise answers.
(printer A)
(printer B)
James Gallant
Graphic Designer
From the second image, it does appear that there is something wrong with the black nozzles, maybe a head strike or it was improperly transported from the seller to you. A couple things you can try for both printers.
For Printer A, you can try replacing the dampers to see if that helps, if it doesn't, there's a good chance there's a crack in the manifold, which is fixable if you're handy and are very careful. Most likely needing a new head if neither work. This is also dependent on you keeping it run and doing cleaning cycles. If it's been sitting unplugged for a while, you could be looking at a much bigger job and the head will certainly need changing.
For Printer B, you can try a 48 hour head soak and topping off cleaning liquid after 24 hours and see if that improves anything. You could also try connecting a syringe to the line after the cap top and pull ink through and do a cleaning and see if that improves anything. If neither works, you'd be looking at needing a new head for this printer. Did this printer print nice before you bought it?
Hope this helps to guide you in your troubleshooting efforts.
Heeya
Thank you so much for your answer.
Luckily, I was using Printer A for black image.
I want to replace the damper of printer A as you said. But I can't find a manual or video on the internet for replacing the damper. How did you all replace it?
Printer B previously soaked the head for only about 10 hours, so I may have had not enough time. I will soak the head over the weekend and give you feedback.
James Gallant
Graphic Designer
For changing the dampers, you'll first want to clear any ink out of the lines, then power off and disconnect the power cord. You'll have to remove the cover(don't have this printer here), but it uses the same head as my VS-300i. Once you have access to the head you'll need to remove the print carriage cover and then disconnect all the wires and lines, then remove the dampers, then just do everything in reverse. I'd strongly recommend taking photos along the way, will make it much easier for you. I'll also guess someone here might have the BN-20 Service Manual with the steps, but I don't. Hope this gives you at least a vague guide as to what to do.
Heeya
Unfortunately, both failed.
I've soaked Printer B printhead, but the nozzle test showed the same result.
I've also soaked Printer A printhead and the nozzle test showed that the middle part did not print at all, as shown below. So I immediately replaced the dampers, wiper, and cap top, but the middle part still does not print. It seems like the situation has gotten worse.
Do the both printers really have printhead problem?
James Gallant
Graphic Designer
Based on those photos, yes, both Printer A and B have print head issues and would require replacement unfortunately. What I might suggest is if you get them both replaced, you could always sell one afterwards and recoup some cost of the heads.
Reactions: 1 users
the second printer, the damage to printheads should be visible to a blind man, if you stop the carriage in the cleaning or inspection position
damonCA21
With printer B did you see an actual test print from that printer? That damage to the head hasn't just happened, the seller would have known that was there. I have heard of sellers who will photograph a test print from another printer and pretend it is from the one they are selling! Did you buy it from Ebay? If so you should be able to return it.
The bad news is that neither printer is going to work properly without replacement heads.
Heeya
For printeahds found this. Don't pay more than that!
The original price was too expensive, so I hesitated to replace the head myself. But at this price, I'm confident enough to try! Thanks a lot for your recommendation
Jim Hancock
Old School Technician
When I say "Walk away quickly!", it's waving a red flag for you. Search this forum about vendors from Indonesia and Malaysia. If, and I mean if, you do receive a head, the likelihood of it working properly or for very long is doubtful. It will probably be any of the following: a really cleaned up used head, a dead head, or a factory reject. Or you may get lucky and get something that works. If you still want to pull the trigger, then DO NOT do a wire transfer. Use something like PayPal or Venmo to shield your payment data. Good luck!
Heeya
Because it was a private home when I visited, so I don't think he was a professional scammer. We did test prints right there, but the test images weren't the kind that would expose a black nozzle defect, so it went unnoticed by me. I'm now aware that black nozzle issues are common with the BN-20, but back then, unfortunately, I had no idea such a problem could occur. o_O
Heeya
Oh, I misunderstood what you said. I hesitate to buy it at a high price because there is a possibility of failure if I replace it by myself. Can you recommend a company?
Jim Hancock
You are in Germany. Reach out to Damon, he would be a better person than I for sources on your side of the pond...
