Braille Inserter
gregjordansr
While I don't have a direct alternative to the Accent inserter, some users have suggested exploring other options like the Xenetech Engraver Raster Braille Inserter Bracket, which is compatible with Xenetech engraving systems and may offer a more cost-effective solution.
tulsagraphics
Xenetech also uses the Accent system. So while there are "brackets" out there for various engravers, the inserters and braille license(s) must be purchased separately.
(check description - the photo is misleading)
Robert Wilcox
I'm not sure what you mean by this?
I've used the raster system for about 10 years, it's a solid system and definitely made us some money over the years.
About a year ago we decided to give the quill a shot, we regularly get orders for 200+ signs with braille and the braille was always a bottleneck, mostly because Noone wanted to insert the beads for 5+ hours a day.
The quill system is easily 5-10x faster than we were with our raster setup. We can now apply braille to 200 stairwell signs in an afternoon, and if something messes up you just wipe the uncured resin off the sign and try again, with the raster system, if a single hole isn't drilled deep enough, it's a major PITA to fix.
When we first got the quill, there were a few bugs that needed to be ironed out, but they do take feedback seriously and have worked out most of the issues.
I can't imagine going back to drilling holes and inserting beads!
Hello how do the Braille dots hold up with the quill? I’m wondering if I could buy some sample off you to do some tests with.
Im considering buying a Shopsabre with quill attachment. I would mill around the copy leaving it raised and one piece with the substrate. And either using the quill for the Braille or maybe milling around the braille hopefully leaving it raised and domed.
What do you think?
I know the background will most likely have lines but I can probably sand them down.
JBurton
Signtologist
What do you think?
You can just get the materials from johnson plastics and route and remove the excess pieces using a shopsabre. I did 80 stairwell signs on ours because it was way faster than on our engraver. Only issue was the heat causing the adhesive to stay stuck to the background more than usual.
You can get a sample of the quill beads direct from them, I ordered the sample, was fairly impressed, but ultimately decided it wasn't for me since we don't do tons of braille, but more importantly, our cutting room isn't that clean, and I could see dust getting into this stuff before it cures.
B_Rollins
What do you think?
You can get samples from the Quill site. It's one of their products, can't remember if it costs anything. The hold up really well from my experience.
MikePro
CanuckSigns Just curious... how do folks send you orders for big ADA jobs?
In my experience, 95% of the big jobs literally start with a GM walking in with a big stack of blueprints "Here, figure out what we need to be compliant and bid it". Oof. Who has time for that?
(This was great when I had an architecture student working for me -- I'd just give it all to him. He loved it. lol)
Was I just unlucky with clients? Or is that how most ADA jobs go?
its how our big ADA projects go as well.
i've always thought these efforts should fall on the GM, as they should already know the quantities based on doorframes quoted buuut whatevs.
quite annoying, but worth the effort for the salesman ...because undercounting results in losses that come out of their commission/paycheck.
  • Agree
Reactions: 1 user
JBurton
Signtologist
"You're the sign guy! You should know if this door needs a sign"
"Ok, they all need a sign!"
Proceeds to sign off, cut po, then ask if they really need a sign here, can't put one there because that's where something else goes, proceeds to put urinals in a gender neutral bathroom without a lock, etc.
  • Agree
Reactions: 2 users
tulsagraphics
Do architects ever provide lists of required ADA signs with their plans? Surely they know a great deal about ADA requirements -- and with all their fancy software -- seems logical they'd be able to create a sign list too. Or do they not get paid well enough for that? lol
  • Hilarious!
Reactions: 1 user
crashaffinity
We just ordered a couple quills looking forward to trying them
CanuckSigns
I usually get a list of sign types from architects, but the GC's never give me an actual list, or a design, they want me to go through their floor plans and make a list and design a sign system as well, and they will send this to 10 shops, who all come back with completly different prices and designs. I don't do this anymore, waste of time.
  • Agree
Reactions: 1 user
JBurton
Signtologist
In my experience, only when the owner is involved because we already have a realationship. They'll turn the screws on the architect to get the apropriate signage listed. It'll still be wrong, but at least we can point fingers.
Have you seen the signage that architects slap on buildings? Around here it's always arial, and the gc will get quotes on channel letters, nobody thinks twice, and before you know it, there's a cheap af looking sign 6' tall X 40' wide on the side of a monster building.
  • Agree
Reactions: 2 users
guillermo
I do braille also, no so often but when I drill and they are not deep enough, I just take my back up drill and do about 1 to 3 turns on that hole manually and it works, I do this once or twice when I do braille, until I get the proper depth.
