Braille Inserter
gregjordansr
While I don't have a direct alternative to the Accent inserter, some users have suggested exploring other options like the Xenetech Engraver Raster Braille Inserter Bracket, which is compatible with Xenetech engraving systems and may offer a more cost-effective solution.
tulsagraphics
Xenetech also uses the Accent system. So while there are "brackets" out there for various engravers, the inserters and braille license(s) must be purchased separately.
(check description - the photo is misleading)
Robert Wilcox
I'm not sure what you mean by this?
I've used the raster system for about 10 years, it's a solid system and definitely made us some money over the years.
About a year ago we decided to give the quill a shot, we regularly get orders for 200+ signs with braille and the braille was always a bottleneck, mostly because Noone wanted to insert the beads for 5+ hours a day.
The quill system is easily 5-10x faster than we were with our raster setup. We can now apply braille to 200 stairwell signs in an afternoon, and if something messes up you just wipe the uncured resin off the sign and try again, with the raster system, if a single hole isn't drilled deep enough, it's a major PITA to fix.
When we first got the quill, there were a few bugs that needed to be ironed out, but they do take feedback seriously and have worked out most of the issues.
I can't imagine going back to drilling holes and inserting beads!
Hello how do the Braille dots hold up with the quill? I’m wondering if I could buy some sample off you to do some tests with.
Im considering buying a Shopsabre with quill attachment. I would mill around the copy leaving it raised and one piece with the substrate. And either using the quill for the Braille or maybe milling around the braille hopefully leaving it raised and domed.
What do you think?
I know the background will most likely have lines but I can probably sand them down.
JBurton
Signtologist
What do you think?
You can just get the materials from johnson plastics and route and remove the excess pieces using a shopsabre. I did 80 stairwell signs on ours because it was way faster than on our engraver. Only issue was the heat causing the adhesive to stay stuck to the background more than usual.
You can get a sample of the quill beads direct from them, I ordered the sample, was fairly impressed, but ultimately decided it wasn't for me since we don't do tons of braille, but more importantly, our cutting room isn't that clean, and I could see dust getting into this stuff before it cures.
