CalamityJay
See attched.
My shop uses this excel file to calculate the remant pieces of cut vinyl from production.
I'm just trying to help others out and eliminate some waste.
The .xls file is setup for a summa t seties s120.
Oracal is the vinyl we use at the shop.
I use circle carabiners to hang from a shelf.
http://www.amazon.com/Aluminum-Round-Carabiners-Assorted-Colors/dp/B003ZUMJSI/ref=pd_sim_sbs_sg_2
Just pull off clip when you need it.
One idea that might also be helpful to catergoize is to number each sheet.
*It would probably help you not have to measure each sheet when going to find a remant sheet.
Making use of every SQIN helps!
