CNC or Laser?
rjssigns
Sold my old printer to make room for the new printer. Wife recently said she wants a laser. I'd like to have a small format CNC with 4'x4' cut area.
Products...? Industrial equipment tags for the time being. Other than that grow into the rig.
What do the Signs 101 experts say?
Christian @ 2CT Media
Cnc router is much more flexible if you get a good one, laser has severe limitations to what it can process. We have both and I would start over again with a cnc unless all of my work could be done on a laser.
rjssigns
Thank you for information. I also think a CNC would be a better choice. Found some Gerber 404's on the web. Look to be built like a tank.
Now to tell the wife...
James Burke
Be a good guy and tell her she can have the laser.
JB
shoresigns
If you want to "grow into it", it probably makes sense for your first CNC to be a traditional one. Then, when you eventually outgrow it, add a laser and/or waterjet.
Unless you need particular capabilities that a laser might be better for, like wood burning.
Laser - Straight Cuts and Engraving. Going to be limited by the laser that you can afford. Will depend if your able to cut through wood and aluminum or if your only going to be able to engrave on wood and aluminum.
Traditional Router - Cheaper price Point. Greater range of ability. Far more materials you can use. More finishing options as well.
Although a laser would be perfect for small tag engraving. Just buy blank tags and engrave away.
Going to get about 1/3 the size of a laser machine as you could afford if you went the traditional router way.
rossmosh
Industrial tags is way too vague.
For a sign shop, I'd say a CNC Router is more valuable. It won't take that many cut letter projects to justify the cost.
If you're looking to do smalls, the laser a more efficient machine in many regards. Setup and production is typically more straight forward
mark-s
I went with a 4X4 diy cnc and love it.
Can do nice size signs and smaller things.
mark-s
CanuckSigns
We have 2 lasers, there have been times I have considered a CNC router, however there is a guy around the corner with one that we send stuff out to when needed.
Keep in mind a CNC requires a bit more planning, they are loud and dusty, so you need to have a way of keeping the dust out of the rest of your shop.
The lasers require punching a hole in the wall and running an exhaust system to the outside,. You can't cut anything with PVC in a laser, and most of the machines you would be looking at can't cut metal either, you are limited to wood and acrylic really.
mark-s
TomK it was a pieces and parts thing, A friend of mine a tech wizard put it all together.
I was just the helper.
It works well and I love it.
mark-s
rjssigns
We are trying to get a demo set up... We want the 6x12 with 9kw auto tool changer and 200w kern for acrylic cutting and metal engraving.
Nice! Sounds like a beast and ATC is awesome. In prototyping class we ran Haas VMC's with tool changers.
Can't wait to hear what you find out.
Gene@mpls
I have a Chicom laser [3x4' 130w] and a 2x4 shopbot and use the laser 50x as much- no holddown and very fast. Totally different beasts, a hybrid would not be a good idea IMHO. Depends on what you do.
