Kemble
I have a Graphtech CE3000-60mk2
My dongle for my VE LXi Master+ 7.5 program broke on me and windows will not recognise it anymore. I hopped in the car and drove 1.5 miles to a buddy's shop where he gave me his old flexi 7.6 because he's now using flexi 8 cut & print. I uninstalled VE LXi and installed flexi 7.6. I open up any of my saved files, even brand new files that I create and when it is sent to the cutter the cutter decides to repeat a pattern over and over again moving in a diagnal path. For example when I created an 8 inch circle it would start the cut at 3 oclock and cut counter clockwise. when it gets to 9 oclock it would start over at 12 oclock from that 9 oclock origin and go from 12 to 9 over and over and over again across the entire length of my media then when it gets to the end of the media my plotter would read "OFF SCALE". Other files it would choose a different pattern and do steps across the entire length of the media. Sometimes when it stops at the other end of the media after making its repeat pattern it would go back to the original location after about 10 seconds and finish cutting the image out and sometimes it stays at the far left of the media.
I called sign warehouse tech support and he walked me through resetting the program preferences and we reset the cutter defaults by holding the up arrow and turning it off and on. After about 2 hours of trying this and trying that he told me he had no clue and it was going to be forwarded to a master technician.
I figured I'd ask here to see if anyone has experienced this problem before and what they did to fix it.
I didn't want to tell the technician that I was using Flexi 7.6 because I wasn't sure if they would help me trouble shoot my problem because I didnt buy the flexi from them. From using both VE LXi 7.5 and FlexiSIGN I couldnt see anything different except for the flash screen that poped up when you loaded both teh program and the production manager.
Do I need anything different like drivers or anything just because I went from VE LXi Master+ 7.5 to FlexiSIGN 7.6 ?
Thanks in advance
Thanks in advance
Sorry about that Kemble. Your individual issue was overcome by what for many is a volatile topic.
