Contour Cut Duh Moment
JamesLam
So, I added a contour cut to an image but for some reason beyond the stars I selected a segmented line, not a complete line. Of course when the cutter does it's thing it only cuts along the segments, not the entire circle as required.
Can this be modified or edited in PM? Or am I cutting the rest out by hand?
If you used crop marks/registration marks, in theory you could just drop a solid line over the segmented one, delete the segmented one and send it back through the cutter. It's possible it cuts through the backer though without vinyl in certain parts to cut through.
JamesLam
Here's a partial screenshot. As shown in the image the circle which was to be a full circle cutout is segmented.
Can this be edited in PM or am I toast?
Not a huge deal if this is blown as it's only 100 stickers, but possibly a trouble shooting & learning moment.
JamesLam
No crops used.
JamesLam
Technically you could still use trial and error to find the proper origin spot that will make it cut at the exact same spot but that will be very time consuming unless someone else has an easier way to do it.
I think I have to admit defeat and move on.
Now there is a transparency feature in PM but I have the HP version and I'm guessing that's why I don't have that feature.
