Beyondcustom
Hi I have a Roland true vis 540. I’ve calibrated the cut and it’s almost perfect. But when I send a file to cut the cut is always off. Could someone help me fix this Thank you.
With more it gets worse. And some move more than others. But yes the same directionAlways the same amount and the same direction?
WOW!Call a real tech
I also had a VS 540. You refer to print then cut? I fought this for years. Dumb fix for mine. Always justify print to left (home) side. Never center justify.Hi I have a Roland true vis 540. I’ve calibrated the cut and it’s almost perfect. But when I send a file to cut the cut is always off. Could someone help me fix this Thank you.
You upset that I gave him an honest answer or you just want him to fester in his own mess ??WOW!
