convert jpeg to eps
BryWY
I have been given a Jpeg file to cut out a logo on my Desay Master 380 P vinyl plotter I convert it toan eps file but I cannot unmask uncompound break it apart or ungroup it to cut different colors can anyone point me in the right direction? I use flexi software.
Snydo
In flexi try using the Bezier command under the Bitmap menu,then Vectorize then Bezier....this is assuming your version of flexi has this feature. Good Luck.
BryWY
Jpeg to eps
4 choices auto trace centerline trace color trace and picture cut
i tried auto trace and bezier is no longer availble
in flexi try using the bezier command under the bitmap menu,then vectorize then bezier....this is assuming your version of flexi has this feature. Good luck.
Jburns
Since you are using flexi- after tracing - right click - select within will help you unmask- and ungroup
also unmask should be an option on right click
player
There are 2 types of files we work with.
One is is bitmaps or raster, which is like your tv or monitor. The image is made of pixels. Photos are rasters.
The other file type is vector. The image is made up of vectors or lines. This is what you need to cut on your plotter.
You can usually tell what the image will be like by the file type. .tif .jpg will always be raster. .plt .dxf will always be vector. Some like .eps and .pdf can be either vector or raster or both. So saving a .jpg to .eps does nothing to alter the file contents other than changing the name.
As others have stated you must trace the raster or photo image to get the vectors.
Sign Works
Better question would be ... Why do you own sign software and a vinyl cutter without first knowing the difference between a raster image and a vector image? Isn't this like putting the cart before the horse so to speak?
Also ... You do understand that file format does not always dictate image type, right?
Fred Weiss
[video=youtube;G_shkeAk7Qk]https://www.youtube.com/watch?v=G_shkeAk7Qk[/video]
[video=youtube;Tx4LNLz30a4]https://www.youtube.com/watch?v=Tx4LNLz30a4[/video]
bob
Since the OP already has a copy of Flexisign, please explain why he should go out and buy a license for CorelDRAW.
A bitmap tracing utility that's infinitely better than the neolithic thing offered up by Flexi.for openers. Plus a couple of other really handy things that it can do and Flexi can't. Like area fills and, with one notable exception, a more civilized node editing capability.
GAC05
Quit buggin' me
Will it work if it is a vector cart and a raster horse?
