Need Help Correcting color and keeping things consistent.
Jharris81
So not sure if this is the right place to put this question.
Soft the longest time I have been dealing with getting good grays out of my xc-540 and have posted a few times on here about it. Well after a long time I have been able to get a decent grey color out of my printer and a relatively happy with it by adjusting the color curve to get what is a good color all around. Well yesterday I decided to print a Roland color chart directly from versawerks just to have a new one and make sure everything is how it should be. Well it does not let you add the corrected color curve or icc profile to the color chart or I am just missing something. I guess I can see why they would do that but then how are you suppose to get a good color representation if the color chart isn't corrected for your printer variations.
Since I bought the printer my greys have always been very green and the only way I have been able to correct that is with adjusting the color curve. I there something that I am missing that I should have done when I bought that machine? Should I have factory reset it, is there adjustments in the actual printer that would hold an old icc profile of some sort that would need to be cleared out or what. How would I return to a corrected baseline for my prints without having to make sure that I have to have an adjusted color curve or custom icc profile just to have a printer that prints correctly. I get have an icc profile or minor adjustments just for slight visual appeal or whatever but having that machine be way off just doesn't make sense.
Hope this makes sense.
Stacey K
I like making signs
Probably the easiest way to correct it is to print out the pantone color chart or whatever chart it is you use in your program and use the grays you printed out that you like best. Mine are printed so the boxes are about 1" and I cut it apart and binder clip it. That way, I can take it with me or put it next to a car or truck, etc. to match colors. Also, when I get a good rgb or whatever other color that prints nice, I save it in my color swatch and name it after the customer "Pigeon River Blue" "Graphix Green" etc. I tend to use the same few colors a lot for all my jobs. Gray is a hard color to hit correctly so these charts make it easier.
Reactions: 2 users
Jharris81
. View attachment 178927
I get that I can print out colors charts and use a color that matches but my thing is that if I am printing a Roland spot color chart from my printer that I know is printing grays with a green hue how am I suppose to use that color chart if I can't add a icc profile chart to the print to correct for my printer. I feel like I am adjusting all these different thing, icc profiles, color swatches, monitor color, color curves, to try and adjust for a printer that at default, or attest what I think is default does not print correctly. Kinda that whole saying that a house is only as good as its foundation.
Maybe I am going about this or looking at this all wrong.
Color correction is probably the most misunderstood and underutilized aspect of the sign printing industry in my opinion. Especially for smaller shops who see the upfront costs in the 1000s of dollars and decide to rough it instead. The answer to your question is basically, you need to make your own color profiles and linearize your printhead output. Short of that, you're stuck doing it the way you are now which , as you know, is a PITA.
When a printer is not “linearized,” it doesn’t lay down the amount of ink you think it is. For example, you might tell it to print 50% magenta, but the head may only put out the equivalent of 38% magenta. That means the printer isn’t actually following your instructions, and the colors you get on paper won’t match what your file says.
Linearization is the process of correcting that. You print a chart of swatches from 10% up to 100% for each color, then measure them with a spectrophotometer (a tool that reads printed colors). The software compares the intended value (like “50% magenta”) with the actual result and adjusts the curve so they line up. After linearization, when you tell the printer to print 50%, it really does 50%.
This matters a lot for neutral colors like gray. A gray in your file might be equal amounts of CMYK (say 50% each). But if the printer is outputting uneven amounts, like C40 M55 Y48 K39 instead, your gray turns slightly green, bluish, or magenta-tinted. That’s why, without linearization, grays drift all over the place. With linearization, the printer’s densities are corrected, and grays (and everything else) come out the way they’re supposed to.
Knowing that, you might think, why not just print a percentage of black only? Which is a valid option but they tend to come out looking brownish and grainy without the other colors. You can test it out by using the color replacement tool in Versaworks, select the color you currently have as gray, and replace it with whatever percentage of black only you want to try. That will override the profile and print what you tell it to.
Reactions: 3 users
Jharris81
Just random thought about all this, I there anything that a previous owner could have changed on the printer that a factory default would help or is all of that info ran through VersaWorks. I bought the printer and just left it how it was because at that point I knew zero about wide formate printing, or printing at that.
Nothing on the printer end other than the nozzle check. If you're missing nozzles, that will affect color for sure. Otherwise, color correction is handled entirely on the RIP/Computer side of things.
Jharris81
ok, Ill my head are new within the past year. I didn't figure there was but figured id ask. Defiantly frustrating when you just want to be able to print what you see and it doesn't work that way.
Absolutely and you are by far not alone. This is probably one of the most common struggles in the industry.
Saturn
Your Ad Here!
Curious if anyone has good firsthand experience with an on-site or remote profiling service. Any price range.
Jharris81
I have called all around my area and no one can help with color profiling. Everyone is just fixing machines. I would like to know if some that can help with that as well
Mike Adams
Correct Color
[email protected]
Phone or text: 512 468-0010
i thought color crest offered a service similar to what you are asking for, in the past.
i may be confused, or he may have given up offering the service
i am skeptical of the remote profiling, not because it isn't possible, but, because you may need to relinearize to compensate for variations in batches of ink, white point on substrates,
aging of print heads and other reasons as well.
Superior_Adam
I also hate when people say "well its blue on my computer screen but it prints purple". Also keep in mind that if you get the printer color corrected you have to do it for every media that you print on. If you have 50 different materials you have to build a profile for each one as the white point of the materials will be different. You can usually get by with doing 1 depending on how picky you want to be as it will vary slightly between different media types.
Reactions: 2 users
we have an I1 at every desk so there is no excuse when we get a different material to print on. (although I am the only one who consistently uses it. )
Fechin
Signs around Chicago
I guess its on a similar process as this. First, I use Onyx so I don't know if its quite the same. Second, to know exact colors I've printed a CMYK chart of 10 pages(see attached). Everything is a spot value and color profile is off, that way when its loaded the Rip converts it as is. So my 10/40/20/10 square is that and not 12/37.7/16/15 or something.
So now I basically have a little booklet for each printer showing their values and I can see the difference in colors between the Latex and the Solvent's values.
When I need to match something I can look up the value and spot color it in depending on the design. Sometimes I just need to Spot color that value in illustrator and load it with the profile off. More complex things with multiple spots I might have to convert it as a raster with those values and do the same.
This way I can also keep a record on pantones. I have an excel sheet of them based on their number and which printer so I can easily use them or I consult the CYMK booklet to quickly find a range for a print sheet(ex. printing a spread of 10/0/10/0 to 30/0/20/0 if it looks like it sits inbetween those.)
  • cmyk.pdf
Think713
Have you done linearization on a HP through Onyx?
austind
The solution that has worked for me for the last 16+ years is using Mike Adams with Correct Color. He's written custom profiles for all my machines, and they generally last until I retire that printer. We print on a wide variety of substrates, and print from eco-sovl, latex, and UV cure printers, roll-to-roll, flatbed, and hybrid. We don't profile all of our materials on all of our machines, usually just our big 5, and the profiles Mike makes are always more than adaptable to similar materials.
Trust me, save yourself the expense and headache of going it alone or tolerating those awful canned-profiles.
Call Mike Adams with Correct Color:
[email protected]
austind
Mike Adams
Correct Color
[email protected]
Seriously, Mike's the man! He turned my workflow around, streamlined my color management, and gave me reliable machine-to-machine color matching. I will sing his praises to everyone. 20+ years in the print industry and the last 16 using Correct Color.
i will agree, because even if i loan you an xrite I1 it will not be a prize package the first time you try to do it.
Stacey K
I like making signs
If you can't get your machine calibrated...
I hate to be such a simpleton but when people send me files and I can't see them in person to go over colors, I might say, "The blue you are using on screen is very close to Pepsi blue, is that what you are going for?" Most of my customers are small businesses and they aren't that picky. I have some standard colors that I use most often for the basics. I just did this for a landscaper in town. He wanted a bright green, I said, "Do you know XXX business? I just used a bright green on his trucks, is that the color you are thinking of?" - and yes, it was. Problem solved in 5 seconds.
I know my system isn't very scientific, but it works for 90% of my customers. The pickier customers, I typically print them several samples, laminate and they choose which they prefer. OR - larger companies have brand standards they can send you so you can print the color then match it to your color bridge and adjust from there. I then print, laminate and save that color and label it so I can make sure it's always printing the same. I also save it in FLEXI and label it for future use.
If you're dealing mostly with small businesses or "people" try and stick with some of the same colors and use them over and over for jobs you can. There's no sense in having 10 light grays when 1 or 2 will suffice for 10 jobs. I use Oracal vinyl so many of my colors match those colors and it just keeps things simple so you can interchange print and cut vinyl and everything matches nice.
  • Informative
