Could my heat press be the cause of my headaches? and if so help me pick a new one!
heyskull
We have a seperate thermometer to check our press comes up to temperature.
I would advise buying one as the temp settings on the controls are way out on ours.
Also check you are using the correct vinyl for the material you are pressing.
SC
d fleming
Same thing we all tell our customers about signs, you get what you pay for. I have had many heat presses over the years and have always done good with hotronix.
Mike_Koval
the inconsistent temps are your problem. With the cheaper off brand presses, this is a very common problem.
You need three things to ensure a properly applied transfer
1. Even heat/consistent temp
2. even pressure
3. proper time
If any of these are off, you will encounter problems. My recommendation to you is stick with a name brand...Hotronix is going to be your best press option. Let me know if you are interested.
That seller had 14 negative and 16 neutral feedback responses in the last month. Wow, not good.
I did not get it from that ebayer-- it was just the same kind
yes, that is the problem
the temps have to be right
:thumb:
get a hotronix
Looking into them
thanks for the feedback!
2. even pressure
3. proper time
your the man about this kind of stuff!
I will take your work and get a Hotronix from you
Your biggest mistake was buying that Chinese press.
Your telling me!
I'm saving up for a Hotronix Fusion. Maybe you should too.
same here
Mike_Koval
if you are looking to stay within a budget, check out the Stahls MAXX.
Manufactured by Stahls Hotronix as well. No auto open feature, but still a great option at a economy price.
