Could use some help on this one Please!!!
Sign_Boy
OK here's my question.
There are a total of 4 sign faces on an existing pylon.
The area to be lettered will be:
1: 47" x 21"
2 colors + a digital print (the print will be 21"x21")
There are 2 of these
2: 82" x 19"
2 colors + a digital print (the print will be 18"x18")
I will have to remove vinyl from all 4 faces. There is quite a bit of vinyl on these.
They want to use the existing faces because these signs will be temporary.
I will not be using Trans to help keep the cost down.
I was told they don't want to spend a ton on these.
Removal of the faces will require me to take part of the box apart.
Where would you all be on something like this?
Just ballpark it if you could please.
I'm thinking 7 and change.
Am I way off?
Thank you all in advance.
Oh and they want it ASAP
wes70
A lot of vinyl to remove, eh? Using your hourly rate, is it cheaper to remove the vinyl or too simply replace the faces?
Anyway, if you are removing the vinyl and then re-applying new vinyl, you will have to figure how long it will take and multiply that by your hourly rate and then add in material charge.
Remove the panels, clean off, re-letter and re-install would be about $650 to $750 + permits.
Are you licensed to take these signs apart and back together again ??
If not, perhaps subbing that part out would make it a little higher by $150 or so.
Fred Weiss
Reclaiming faces is a fool's game. I would not do it.
4 new faces cut to size = $320.00
Graphics and application = $530.00
Pull old faces and install new = $150.00 to $225.00
Total = $1,000.00 to $1,075.00
jscarl
Just wondering?. Can you apply a new layer of vinyl over the existing.? How many layers would still hold up.? I have a guy that wants me to do this on a 3' x 5' plastic. 15 foot in the air, lights shin down on it. They will take it down and put it back up, if i think it can be done.
Sign_Boy
wes70 - I mentioned new acrylic, but that was a no go.
Gino - Thank you for the #'s. So I wasn't far off.
As for the license - all I'm doing is taking the retainer wall (edge that screws on the side of the box) off and sliding the panels out.
Not that that's going to be an easy task.
Come to think of it it's probably a 2 man job.:banghead:
Fred - I agree I try to avoid reclaiming faces any chance I get. Those numbers would never fly with this job.:banghead:
jscarl - I don't recommend doing a sign that way. You will most likely have problems.
Thank you all for the help
Fred Weiss
Then you shouldn't do the job. The problems with reclaims are:
1. You can never know until you're done how long it will really take you.
2. There is always a potential for damage to the faces leaving you in the position of having to provide new faces anyway.
3. With new material, you know pretty much exactly what your time and material costs will be. With a reclaim, you are gambling. If I wanted the job, I would let the client think I was going to reclaim the old faces and I would plan on providing new ones anyway.
Sign Boy…..
You’re in the ‘Premium’ section, so I’m going to blast you.
There is NO job that can be legally performed without obtaining a permit first. When obtaining the permit, you must show them your liability insurance and other things which will then lead to if you are indeed capable of legally doing this job. When you have no electrician’s license to be working on an electrical sign, they probably will and should stop you from going any further, thus making you out to be a fool in front of your customer. Regardless if you know how to do something…. you are not properly licensed and are doing the work of a tradesman that SHOULD be doing the work. This is the step right before backyard mechanics vs. professionals. If you do this and insist on doing it, then you are guilty of abusing the system and are a part of the problem. This is why there are so many laws these days and permitting problems….. too many people are ruining it for the rest of us that are doing it by the book.
We do this all the time for various real estate agents, professional buildings and some malls. We have a few to do at the end of this week. We usually take the vinyl off out on site in all kinds of weather [except ice and rain] and put the new stuff up on the spot. Wham, bam, thank you ma’am and we’re good for a several hundred dollars worth of work. For years….. we’ve been removing and re-applying vinyl. Is it the best way to do it ?? In my opinion, when you get to the place to make an evaluation…. You must know right away if this is going to be a problem panel or not. You must at this time tell your customer what their options are. I would venture to say about 90% of all the panels we’ve ever removed vinyl in place worked without replacing panels. Do we try to talk our customers into new faces…. Heck yeah, but most of them in the last ten years can’t hold onto tenants more than a year or so…. sometimes less. They can’t afford new faces.
A new business taking over a building is s different story. This is where knowing the whole story can mis-lead the reader in the forum. In this case, I then would never do a job on site. Then I give the customer a 50/50 chance of re-using the faces. Take ‘em down and decide inside. Usually the faces are replaced.
Sign_Boy
Fred - I kind of agree with you on this one. I would have something in writing that states I am not to be held liable for any possible damage that could occur while working on this job. I would also have them sigh off on something that states that I recommended new faces for this very reason.
Gino - Blast away!!!
OK I need to look into that one. I have no problem showing them anything that has to do with my insurance. (I'm in NJ and I sure pay enough for it)
As for the electricians license? One would be needed to take an end cap off a box slide a few panels out and back in? I'm not rewiring anything here.
Just so you know I'm not trying to be a smart a$$ here.
As for these faces they will be temporary. I also thought about pealing onsite, but figured this would be a huge pain.
wes70
Something that you should also consider is your reputation. I've been guilty myself in the beginning by "helping" the customer by trying save them a few bucks. I soon found out that these jobs will only hurt you in the long run. I know during these hard times it's tempting to take on all jobs, but at times you have to pick and choose... this may be one of those times.
So because you're removing the faces and not touching the wires, that makes it Okay ??
  • While you're there, do you know what to look for while it's opened up ??
  • Do you know what to do if a bird flies in there and shorts something out ??
  • If you lose your balance and hit something inside the can.... do you know what to do to fix it ??
  • While you're away fixing this thing...... what if someone throws something in there..... do you have a temporary face to cover the area open to the elements ??
  • Does your insurance know you're up on a ladder with your head inside of an electric can..... and you're not a licensed electrician ??
All of these above questions can be furnished by a competent sign serviceman which by the way will be wearing safety equipment and harnesses. Will you be wearing one or just winging it ??
Here folks, is where the parting of the ways has to come in. Should you Sign Boy..... or anyone else attempt this type of job and something God forbid should go wrong.... your insurance company will drop you like a Hot Potato.​
Remember, lives can be at stake here and the difference between knowing this and being properly insured and licensed is the difference between owning your business and having your whole world taken away one afternoon on a ladder because you..... thought !!
It's one thing to have customers sign waivers if something goes wrong against your recommendation, but you can't have a customer sign a waiver not holding you responsible for something you don't know how top do in the first place.
Techman
This is not a socialist country we are a capitalist country. That means we our system is here to make profit. Doing a job well done means profit. Better job means more profit. We are not here to let the client save money. We are here to provide a great product at the highest price possible. We are here to get as much as we can from the clients pocket.
All of this in a safe reliable manner. That means obeying the rules.
Sign_Boy
OK so maybe I'm ignorant when it comes to the sign business!!!!!!!
I didn't realize changing a few sign faces was such a big deal.
I guess I need to read up on all of my states policies.
No I'm not trying to be rude or nasty.
I just figured if all the proper permits were in place I would have no problems changing some faces.
Do I do things 1/2 a$$ed? I would like to think that I don't.
The way I see it there are 1/2 a dozen other shops out there that can do the job.
I wake up each morning hoping that my customers know that I stand behind my work and that I am willing to do the absolute best that I can for them.
If I can't do that then I am more than willing to pass on a job.
I guess that I have a ton more to learn about the ever changing laws and regulations in our industry.
Once again thank you all for the sound advice.
PS - it looks like this guy doesn't want to spend the $$$ for this job - so I guess all is safe in the sign world.....
Sign Boy…..
Please don’t take this as a tongue lashing towards you. No one said you were ignorant, half assed or any such thing. Don’t put words into my mouth. I’m quite capable of doing that myself. By your own words though….doing this job, you might just be doing your customer a disservice.
This is a question that is asked over and over and now that it’s been asked in the ‘Premium’ section, I feel it should be answered honestly instead of all this tip-toeing around the bottom line. City Hall will take a permit from anyone…. it’s money, but if…. or when something goes wrong, you’ll be the one in trouble for omitting certain information. You’ll burn by yourself. No one will take the blame with you… including your insurance company.
Actually the laws have always been on the side of the consumer and most professional sign shops abided by these same laws for decades. When so many new shops pop up doing things their way instead of by the codes or law is when more and more laws have to be written to stop people from taking the attitude…. Well, I’ll do it until I get caught. That‘s the very thing that makes this business harder these days.
There was a thread a week or so ago about a guy wanting to do some window decorations and I was the only one that spoke out about getting it approved first. Every other response had the same frickin’ attitude…. Ah, do it until you’re told different. Well, that’s the very mindset that sets the real professionals apart from the backyard mechanics. No one is saying you don’t know how….. we’re just saying you don’t have the authority to do certain things. Until you do, don’t wreck it for those of us that can do it. If that’s called paying your dues… then so be it, but at least we can sleep at night knowing we haven’t cheated to steal a job from someone else.
