Countertop Material for UV Printing
jasonx
Does anyone know of any material that can be used as a countertop matt material. Something like a clear PVC or similar.
bigben
Not a newbie
Sorry, can't help. But I'm curious to know the answer. Let me know if you found something.
Andy D
I saw a really nice counter top print at our local liquor store, it was mostly
a Crown Royal advertisement with some personalized information. The owner said
they put it in free of charge.
To me it looked like floor graphics with a real thick textured over laminate.
Next time I'm by there I will take a picture to see if it's the same as what you're looking for.
rjssigns
Digital print on calendared with 10mil textured laminate.(could probably get away with 5mil textured) You're welcome.:Big Laugh
rjssigns
Really? I have never seen clear styrene.
Agreed on the "Great Minds" BTW
I order it from my sub. Has a slight texture to hide scratches and dings. Normally use for trade show displays. 0.030" is what we order as it can be rolled and put in a tube. Can go all the way to 0.080", but on a countertop it would be overkill.
Chasez
Here we call it PET G... comes in all those different thickness's. I would just use a good lam that is meant for floor graphics (drytac interlam pro emerytex) should do the trick.
Chaz
petepaz
check out a material called G-floor graphics. supposed to be for floor graphics but could also be used for counter top graphics as well. i have used it for both. not cheap but its a good looking product.
another route we have gone is we print a lot of sub-printed overlays so we have textured polycarbonate/lexan on hand. sub print on the polycarbonate and back with white vinyl then you can add adhesive or a non skid backer
I like using a thick 25 mil matte polycarbonate laminate. It's bullet proof. Applying this over a printed wrap looks nice. The other option is the sandwich method which requires some pretty fancy tooling and expensive clear acrylic. Primary Color does this (see below). I don't know about Australia, but if you need to sub it, I might check with Selby's:
http://www.selbys.net/index.html
attachment.php
