Critique my first try at design
shoprat
Just started up with corel draw watching tutorials untill my eyes go blurry, and thought I would give a shot at a design for my first time. Let me know what you think and how I can improve. All coments welcome good or bad, just looking for some feed back from you pros:thumb:
BTW I am not selling this or anything just learning the trade right now!:wink:
OldPaint
i like the cowgirl with the hat. the text brown with black shadow....no good colors to close to each other. look at it and squint youre eyes...and it will turn to a blur. shadow placement seems wrong but iam left handed and alway do shadows to the lower right(old painters thing).also kerning needs to open a little when doin shadows....
i know you want to some nice things with words, but DISTORTIONS aer not one of them. the lasso idea i like but you need it to look more like rope than a string.....there are some ROPES in clipart and ive seen it somewhre in corel i think. you got a good start.....design in black and white..then pick colors.....are you cuttin this or printing?
Steve C.
Not bad. Your black shadow is too close to the same shade as your brown lettering. It would work better if it where grey. If you use the black shade, separate it from the letter with a light colored outline. I think the copy at the bottom would look better all on one line. Too much empty space on each side of it.
shoprat
thanks guys! I will make some changes to it and post up what I end up with. As for the clip art I dont really have a good selection of it right now, the cd I bought had a ton of files but they are not labeled and they dont preview so I think I need to buy some more.
IMO - lose the shadow. The name with the hat needs no further enhancement. I would also agree with Steve and place the bottom on one line, but place digital photography in front.
Looks very good.
shoprat
Here is an update on the changes I moved the shadow some and put an outline around the leters and I have to admit it does "pop" a bit more I kinda wanted to add more design to it with the rope and all but I dont want it to get overdone.
Oldpaint- can I ask why you wanted to know if I was cutting or printing? I would prefer to just cut but if I can figure out how to do both it would be awsome!
iSign
Shoprat,
not that any of these tweaks are "needed" ..but these are some of the changes that came to mind looking at it. First I wanted to lighten the shadow as was mentioned above, even though the white space between black & brown helped a lot. I also wanted the second line centered only to the text without looking at the hat. Then I tried a panel around the secondary copy. It didn't need it, but sometimes I think a design looks unstable, or top heavy with a thin & short line of text at the bottom... although it is done quite often.. I introduced more color which may have been avoided on purpose... but I'm just playin, so played with color too.
It's not better... just different... but it does pass the squint test better from the lighter shadow.
Cadmn
think it was mentioned but line two
"Digital Equine & Livestock Photography"
Might read a little smoother
But it looks good
shoprat
Doug- I am liking the box around the 2nd text line I think I will use it. As for the cowboy hat how did you get the color to fill with the lines not enclosed?
cadmn- I am still on the fence with the word order, to me it sounds better the way I put it. It doesnt seem to flow with digital in front of equine, I guess really it could go either way and be proper.
Thanks for all the advice!!!:thumb:
GAC05
Quit buggin' me
If you are using CorelDraw X3 it is pretty easy, using the "smart fill" tool.
Any place you see gaps just add some overlapping lines with the Bezier tool (D), they do not have to line up or connect, just overlap so there is no gap. once they are done un-select everything and then click in the center of the now closed shape with "smart fill" and draw will fill it for you as a new object. You can then throw away the extra lines you made and tweak it a bit to get the shape of the fill you want. It's a nice tool for cleaning up overlapping vector artwork from other packages that you want to set up for plotting.
wayne k
guam usa
Techman
just pull the nodes and weld.. done
Or. use photoshop and you do not have to close the lines. just mask and spray .. done
