Customer file Just printed and cut price.
JMDigital
Got a customer who gave me a CD with an AI file on it. The files is 100% finished and he wants a price to just print and trace cut. its a 14" circle design. He wants it printed on vinyl and cut out to use at a weekend show.
He wants 61 of them
What would you charge just to print and cut them? no design work..
thanks
Flame
No lamination.....?
Um, $7-$8 each? Just a guess if it's pretty simple and you don't have too weed out too much.
JMDigital
its simple. but I did get new info. He wants me to stick them to something, like coroplast. so 8.00ea plus sticking 61 of them to coroplast that has to be cut.
bob
$11.15 per copy unlaminated, $14.74 per each laminated. Mounted on square cut 4mm add $5.00 each. Mounted on round cut 4mm add $7.00 each.
I don't know the phone number, but a place like 'Stouse' might have, already cut, Cor-X at the size you need. That's a lot of hand cutting circles with a knife. A long time ago, we set up a jig with a band saw and had about 45 circles to cut out of ¾” wood. Each one came out almost flawless. With wood, they had to be perfectly smooth edges, so we needed to sand them a little to get little ‘oopses’ out. Your Cor-X shouldn’t need quite the same attention. I don’t know why you couldn’t stack a few together and cut a bunch at a time with a band saw or scroll saw.
bob
You can. I do it all the time, It's so common that it even has a name, 'Pad Cutting'.
You stack up 4"-5" of pieces, assuming all the pieces are the same size and in register, and tape them into a solid block. You usually tape three places in each direction. This then is your 'pad'. Draw the cut line on the top copy and cut the entire pad on a bandsaw. With coroplast the top and bottom pieces in the pad most likely will need their edges dressed a little with sandpaper or a file. Also pad sawing coroplast tends to want to ever so slightly fuse the pieces together on the cut line. Not to worry, just pop them apart. Don't try to cut them apart, just pop them apart.
Only a masochist would cut each piece individually. Worse, with an Xacto knife, the worst possible choice other than perhaps a hand held double edged razor blade. If you have to cut the stuff by hand at least use a utility knove with a new sharp heavy duty blade. That's heavy duty, not homeowner or regular or whatever, there is a difference.
JMDigital
Ok. Here is a thing, A friend of myne in the tradeshow industry does last min vinyl on coro alot. He has a "RotoZip" with the attachment for circles, I was not shure it would work but it does. He does it all the time. So he is going to do the cutting and I will do the printing..
I allways tease him and say "As seen on TV!" when he pulls it out haha..
Jackpine
Have the circles CNC cut wholesale. PVC would give a better product and it cuts clean. $20.00 each seems good.
maddmd
roto-zip
Here's One
