There is no set way of avoiding this problem.
EVERYONE gives up some money here and there and takes a beating.... however some do it more than others and thus creates a method of doing business that is doomed to fail.
A simple way to avoid your problem Doyle is to simply use the 3 tier method of pricing. You present the cutsomer three sets of pricing that reflect various approaches with various materials. Then, the customer can make a decision based on his/her budget.
In your case, since you already gave him an ultimatum so to speak, tell him you can lessen your prices by lessening your products. If he wants to spend only this and that.... then customize his quote to fit his needs, by using lower quality vinyls or substrates. Let him know he is being an asshole for doing so, that you don't recommend this, but can fabricate it for his special needs and still meet codes. Speaking of codes, tell him can lessen your cost to him, by doing the necessary legwork to obtain said permits. Explain to him that your current price is a direct result of using top notch everything and he can do the instals himself to cut even more money out and better fit his miscalculated budget.
Let hm know you are a professional and only have his best interests in mind and really didn't want him going so cheap, but you can do it.
Now, if you really wanna call his bluff [be prepared to walk away from this]...... make the quote come to less than what his counter offer was and see if he takes you up on it or goes elsewhere. Hopefully, you will get your price, since this guy sounds like a real dick head and he'll do it your way, because he sounds too lazy to do this on his own and if he doesn't go for it.... well, you just saved yourself a whole of headaches.
