Discussion Cut letters / wrap films
letterman7
Somewhere in here I thought I had read about someone using wrap vinyl for "regular" vinyl lettering on a vehicle. I'm facing the same thing - I have a client that just absolutely has to have 3M's military matte green for their lettering on their vehicle (which is black..). It's not a wrap, just their name. So.. aside from the fact that the name will probably not be visible on the vehicle itself, anyone have an issue with using wrap material for cut vinyl copy?
Johnny Best
Have used wrap vinyl with air egress as cut letters, you just can't cut out small letters because of the weeding being difficult from them lifting of the backing so easily.
letterman7
Yeah, these wouldn't be so small, but I would see the issue. Get that occasionally with the IJ180 on some of my "regular" printed and cut stuff.
WhiskeyDreamer
Professional Snow Ninja
I've done this a bunch of times. You just need to test the material to find the right depth for cutting first.
papabud
Lone Wolf
i use my 3m 180-10 for pretty much everything. its either that or just colored vinyl
SIGNTIME
It works fine, transfer tape doesn't stick to backer is the only issue or could be the only issue if not careful.
petepaz
there is a transfer tape made for air agress liners. don't remember the name but fellers has it.
for really small lettering just leave waste material around the lettering and apply the transfer tape then weed it off of the transfer tape.
for small quantity it's not too bad.
Reactions: 1 users
RTape 4075RLA (Release Liner Adhesion) and it doesn't stick to air egress backing. At all. But I still use it, it is high tack so it sticks to matte and satin well enough if you resqueegee it just before install.
