cutting backs of decals for easy peeling
VicoDrive
Im about to run a ton of oval decals. Some decals are slit down the backs of them to make peeling them off the backing a little easier. Is there a special tool for this or generally just done by a knife by not pressing down too hard? Just feel you risk damaging some decals this way.
bob
Producing split-back decals with anything less than specialized equipment usually found only in massive weapons-grade facilities ranges from difficult to impossible.
gabagoo
The only reason I have found to do this is if they are die cut right to the edge and you cant separate the decal from the edge of the paper. if your printing them in house and cutting them on a plotter, there really is no reason to slit the backs... There is a hand tool you can buy to do it, but it is very time consuming and not really necessary.
VicoDrive
I am die cutting these to the edge, not something I have ever messed with before but we are giving it a shot. I had no problem peeling the back off but a couple others in the shop were. Does the hand tool have a name?
oksigns
That back kiss cut would be nice, but you could always add a "tab" of outer material that would be safe to bend back.
J Hill Designs
ive used a plotter blade in its holder, set so the blade peeks out only enough to cut through the backing, and just run it accross the backing
VicoDrive
Thats a thought also. Do you put the material in the machine upside down and have it do it, or take the blade out and do it by hand?
J Hill Designs
I did it by hand (once thickness is dialed in, it takes less than a second), but I'm sure with some planning etc you could let the machine do the work
petepaz
we have a slitter like this (not exact but similar) it has multiple blades and the depth is adjustable then we put our silk screened sheets through and it slits the backs on the entire sheet of decals and then we die cut them. unfortunately ours is so old not sure where you would even find one. but that is what you want for large runs. if you have more then 50 or maybe 100 you don't want to be slitting the backs by hand on each piece
d fleming
Had one years ago, it's been forever since I had to do any slitting. Matter of fact, just sold my challenge paper cutter.
VicoDrive
Just did a batch with the tab, it worked out! Just need to adjust some depth settings for the next batch but it worked. Thanks!
Why did you take on a job you didn't know how to do? How did you quote labor on something you don't know how long it takes to do?
Not pressing down to hard with a knife = scoring.
Enjoy the race to the bottom!!!!!!
VicoDrive
Ill say to you what I say to others with remarks like your....This is Signs 101, not Signs 102
And I knew I could do the jobs, I just wanted to find the best way to go about it.
As for quotes, Im the designer and printer, I dont deal with pricing
