Design Central resizing
Tim D
I just got a new monitor, 22" widescreen. Now Design Central is cut off on the right side. Is there a way to resize the pallet? It doesn't seem to work like any of the other pallets.
Tim D
The question isn't about moving it. I can put it in the middle of the screen if I wanted to. I need to resize it so that all of the controls are visible/usable.
imaSIGNr
If you move it where you can see it all, then aren't all the controls visible ? Are you saying you don't have your fill/stroke editor visible ? click on the option on the tool bar above.....
Sabre
We don't have any issue on any of our widescreens... It looks "proper", but do you know if you're running native resolution for your monitor? I've never seen that before, myself.
slappy
you can always call the tech-support line and get stuck on hold with some man in Pakistan that dosent speak english
RiXaX
I needed to re set the screen resolution on mine to a setting recommended by the monitor manufacturer. I also needed to download a new driver for the monitor so that I could achieve that setting.
Tim D
I had to do the same and that's when the problem started.
Tim D
Here is a better look at the pallets. The right side is cut off. You'd think that you could just click & drag to resize, but that doesn't work.
DRamm76
You may want to try to reset your preferences in the program itself. Or try to reinstall the program and when it reloads it may customize itself to the new settings of your monitor. Hope that helps
GVP
Control Panel -> Display- > Appearance -> Font Size
Don't know if this will help, but might be worth a look.
Tim D
I'll try resetting my preferences, but I don't think I want to reload the program unless I absolutely have to.
GARY CULY
tim ..when you went to preferences ..what did you do there? to fix it [ what should settings be to achieve the answer to problem]
