Design ideas
Atomik Rooster
I have a couple of ideas for a new logo. Looking for the always constructive input from you guys. These are still rough and the colors arent set.
Thanks,
AR
Pro Image
New Age and trendy...............
I can't really read the word design in any of the designs..........
I would try some other font for that...........
MobileImpact
I like the top left a lot! perhaps leave the light green stroke around atomic as it is and try lightening or darkening the background green around it?
Looks good.
Kevin
Jon Aston
Out of all those I like the top right. Are you just doing graphic design or are you doing signs as well?
I agree...and think "Ohio" is asking an important question.
I would add that your concepts all seem targeted toward a younger demographic. I almost ended that sentence with "though"...but maybe that is the point. If so, it works.
high impact
The top two are the best with the reverse panel. Change the font for design. The atomic font is so crazy that it needs a solid, simple bold font for design.
Atomik Rooster
Thanks for the input so far. I also agree and like the top left and think the word "design" doesnt quite fit the bill. I am still hunting through the bazillion type faces i have to find something better suited that will still provide some contrast to the atomik font. I also agree that the burst behind atomik needs some contrast as well.
As far as what I do, I majored in Design and advertising way back when. Worked for an ad agency out of school doing a lot of logo work as well as a lot of freelance airbrush and design work. Got into the building trades after moving south due to a lack of work and now back in Jersey and starting to build my portfolio over again. I do logo design, web design, contractor signs (vinyl), truck lettering, airbrush, know construction and electrical and would like to venture into doing some of that as well. On the back of my cards, I will narrow down to a few specialty type apps and go further on my website when I get a chance to build it.
AR
Atomik Rooster
Some Revisions
Here are a few more ideas. I have 1 I like, but am curious to see others picks.
AR
KR3signguy
the font selections don't connect for me.
I'd think the text should be either more energetic/powerful.
must the radioactive symbol be shown? Could you make it more subliminal, maybe included in the background?
I do like the color combos. esp.green/purple.
If your a designer then your logo should example something more than an out of the box designer font. The logo should be reduced to black & white and be legible from a distance. You might want to simplify it even more.
Take your time!
jeroen
the font you used for 'atomic' is already busy enuf, so use something simple for 'design' otherwise the styles will be fighting for attention instead of complimenting each other
if you insist on using the radio-active symbol, try replacing the 'o' in atomic with it, instead of the dot on the 'i'
Atomik Rooster
More ideas
As part of the creative process, here are some more ideas in a slightly different direction. I do like this design as well and think it will be the direction this logo evolves into. The word design has been hard to find an appropriate font for this particular design, but i think i am fond of the bottom left designs use of the word design. The letters are slightly rounded like they would have been wrapped around the surface of a ball.
Now I need to decide on a border for the design
AR
craigco
I don't agree much on that design. I had to look twice and hard to see the word design. And is look like the word Atomic is in the middle of a bubble bath. Nothing much atomic about that unless........
I Think the other design had more promise with a few changes. Like explained earlier make the word design more legible.
Hopes this helps
iSign
swirling atoms might be more indicative of creative power, instead of destructive power.
I like top right of the first batch... lose the radioactive symbol, & try my orbiting atoms... I like low contrast for your explosive color burst.. keeps better contrast for legability of your logo, which will be good if you ever make a sign with it.
bob
I can only wonder if you keep posting iterations of this clam because your guide dog keeps protesting.
