EDGE2 + LPT extension PCI card?
rudeez
Hey!
I rememberreading somewhere that the edge2 dislikes extension pci paralell lpt cards, is this true or?
I got some major problems when i got myself a new computer for the workstation... It's a AMD phenom2 xII with a Gigabyte m-atx motherboard wich has a built in lpt port. Obviosly gigabyte tends to use a diffrent pinout for some reason, i got the original lpt extension cable to connect to the motherboard but as i said, the pinout is diffrent from normal lpt ports for some reason, and yes iv'e checked everything and been reading up on the forum aswell, really canät seem to solve it, works like a charm when i reconnect it to the old P4 machine so..
My question is, would this exstention card work with the edge2 or?
https://www.inet.se/files/pdf/5400102_0.pdf
It's a Vscom card so drivers and such does exist for all OS systems. Currently running the envision 375 plotter through a vscom extension serial card.
thanks in advance and sorry for the horrible english, i've slept 3 houers tonight coused by thinking about this and trying to solve it..
GB2
Old Member
You need an ECP port for the Edge II. You could also get a USB cable from Gerber, or they have a list of other USB cables that may work too.
rudeez
The new motherboard has ECP support but as i said, the pinout of Gigabyte boards are for some reason f**ked up :(
rudeez
This is the error message i get when trying to print with the built in LPT port on the motherboard. Dunno what it means honestly..
Tony Teveris
On the Omega CD/DVD there is a program called parcheck, this will check your parallel port and see if is truely an ECP port. I think it's in the "misc" folder.
As for other parallel port interface cards I think it best for other users to respond as we at Gerber do not test or recommend any boards.
As mentioned above we do have a USB to parallel cable / driver solution for 32 bit OS only, no 64 bit support but that will be coming
rudeez
Parcheck says ECP. As for USB solution, ive read that it dosen't work for edge2 unless you upgrade the software.. Im using Omega 2.1 so, im stuck in a "moment 22" kinda...
As for sentinel, yes it's confed correctly.
