Need Help Epson s60600 powercord #2 after replacing printhead
Tim-moh
Good morning, I am working on an Epson s60600. Replaced printhead #2 for missing black, cleanings wasn’t helping any. Machine was working ok besides missing nozzles. Followed all step with service tool and service manual, purged lines with cleaning solution, decompress pressure, Shutdown and unplug. After replacing on boot up I am constantly getting plug in powercord message. I have tried resetting cables no change. Any help or suggestions would greatly be appreciated. Thank you
is there a second cord for a heater? or some other aux. device?
as i google it, you have 2, possibly 3 power cords (my mutoh has 4, including the takeup reel.)
did you inadvertently disconnect some sort of control cable between the printer and the heater unit?
Tim-moh
2 plugs for machine and a third plug for heater. I didn’t unplug anything but the ffc cables for the printhead. I am assuming something shorted and it’s either power supply is bad or mainboard.
it's an HP so maybe you have SWAPPED the location of the 2 cords.
SOMEONE had a very lengthy thread a cou ple years ago, where the hp was incompatible with one of the newer circuit breakers.
i believe it was some flavor of GFCI
So, switch the 2 cords and see what is happening
RG
The same thing happened to my Epson when the tech guy was repairing it. I think he just put in another mainboard and printhead. Attached is a page from the service manual. Wish I had better news.
Rayd8
if it's a fuse i guess you could replace that fuse to repair that mainboard instead of costly replace that MB? Does anyone has the specs/location of that fuse so the OP can check it out?
