OK, having a problem cutting some small (1/2") letters on my machine. The cuts are not following the cutting path as it shows on the screen. It starts out cutting the first line sort of ok, but after that, it distorts the curve cuts. As an example, a round dot circle is not coming out round, but almost as if it is hand drawn. The mistakes are the same each time after that, identical.
Any suggestions?
![Thank You :thankyou: :thankyou:](https://signs101.com/images/smilies-orig/standard/thank you.gif)
Any suggestions?
