first 4'x8' sign price check
osco
2 sides 2 color 7 year reflective 4'x8' 6mm alumalite
Hope you guys can give me a price range.
I'm not interested in working for free or low balling. Just would like to hear some prices. I have the Estimate Software but not sure where to set the market level. View attachment sign.bmp
gtjet
$550 for single sided and $870 for double sided in reflextive. We do not use alumalite, we do use dibond, marine grade mdo, etc so I am kind of guessing on substrate cost here but it should be close.
Jillbeans
I'd be at $900.
Please allow yourself a bit of breathing room around the edges of your sign.
The "wrecker service" is too stretched vertically, and your slants don't match in the italics.
(Couldn't help a critique, the same as if we were out to dinner and you had broccoli stuck in your teeth, I'd tell you)
Love....Jill
Checkers
Since you have EstiMate, did you go through the overhead worksheet? Also, did you take the time to figure your production speed? Finally, did you set up an appropriate profit margin?
Once you have all that properly configured, you should be able to leave your market level at 50% and provide a pretty accurate quote that is good for the client and profitable for you.
Checkers
We'd be in the neighborhood of almost $1,100. not installed.
Also, those 'Lions' look a little familiar ??? :rolleyes:
osco
I came up with $900 just didn't know if that would be too high. I think I've got Estimate set up right, just have to learn to trust it.
I made a few changes to the 'wrecker service' it looks better now. THANKS
Roar-r-r-r-r-r-r-r-r....
thar went still another airplane over someone's head, heh Bradster941 ??
Rat_Fink
I would be around $900 for that sign.
You should take the prev advise & use different Lion images.
Most any clipart packages would have lion images that would look better & save you any legal hassles.
Good luck.
R.F.
Jackpine
$900 is good. Change the lions and do what Jill said...the wrecking service is distorted vertically too much. I would remove the slant from wrecking service also.
