gabagoo
I have now run Flexi Photoprint for 7 years. I have for some time wanted to switch out to a more standard way of printing and cutting, but as I get older, my want to learn new things, while juggling customers ever increasing demands and the possibility of having to deal with every aspect of each file and the colour changes..etc is too much for me to even think about....so I stay with this Photoprint software. The software is strictly print and cut only, and you can't use it to cut vinyl graphics only.
That's fine with me as I run Signlab 8 with a different cutter (Graphtec) for all my cut only files...
Flexi in this format is fine as long as I do 90% of my setup in Signlab and then export it down as an eps file and do the final changes in Flexi.
My issue with the software is not so much the software's designing aspect, but the defaults.... if there is a way to permanently change it that would be great, but I have not seemed to find a way...OK so here is what happens about every 3,4 or 5 weeks...sometimes I have even gone as long as 6 months...but for some reason the computer will not load the drivers for Flexi and this box opens wanting to know what printer I have and what cutter. Takes a minute to fix and not a big issue. the issue is that when it reloads the drivers for the Summa cutter...Every file I have waiting to be cut has changed one very important piece of info. The default changes the cut file to delete after cutting.
This is a very dangerous option in my world and can cause incredible tantrums. Once the drivers are reloaded I have to go through each file manually and change the delete to hold. I can't seem to find a way to tell the software to hold everything until I manually delete it. I can instruct it to hold all new files coming in, but not to deal with the existing files.
If there is a way to do this I would love to know.
as it is one of my main flaws.
