FlexiPrint Sends Job, Printer Doesn't Print
shepherddesigns
New issue just started. FlexiPrint version 12 w/ HP Latex 315. When I send a job, it processes through RIP and Output just like it normally does, but the printer never prints anything. I went through HP tech support and they could not find any problems. The printer is accessible through the IP address via chrome. Flexi polls the media width like normal and asks if I want to save the new size as default. When I called to talk to SAi, they basically told me to pound sand that they are no longer offering support unless you have the latest software with an active subscription.
Check the port settings. Flexi tends to default back to "FILE:" instead of the proper port which in your case will be TCP/IP. I've seen that happen a million times.
OutrageGIS
When this happens on our HP 315 w/flexi (version 19 but I had to do this with older versions) I add a new print queue and copy the jobs over. This automatically delets the old queue since HP factory editions (unsupported by flexi) can only have one queue at a time. Sometimes I have to do this weekly
shepherddesigns
Well that rules that out. My next step would be trying to print from another computer. If that doesn't work, it would indicate a printer issue. If it does work it indicates a computer or other hardware issue.
Joseph44708
I Drink And I Know Things
This problem happens periodically with my
Flexi 21.
I have found that by shutting everything down and restarting, everything works great again.
Also every two days I deleat all print and cut files that are finished. I have found if I don't everything runs very slow.
Download Onyx Thrive from Onyx site, install it, install printer driver and try again. Will have 1 month for test.
Next step is to change the router, cable, PC, may be LAN PCB in printer, LAN card in PC. There is cheaper choices for diagnostic.
shepherddesigns
New update. Uninstalled Flexi and then reinstalled in. Added my printer back in and still getting the same result. The computer is definitely communicating with the printer as I can wake up the printer from Chrome. Flexi polls media size and will sync media. I have tried Cat5e ethernet cables and Cat6. All have the same response.
shepherddesigns
What's the difference between Thrive and RipCenter? Seems like RipCenter has everything anyone would need to print.
shepherddesigns
When I run connectivity troubleshooting, everything passes with the exception of Email server configuration settings. No idea what that is for or why I would need it.
do setup, or equivilent for media.
when the display appears normal (ready to print) go to production manager right click on the job in queue [it probably says "unable to open port" or some such ] and choose send
if it prints figure outbwhat is putting the printer offline
shepherddesigns
Just figured it out. Apparently, Flexi only works with certain ports. Port 8080 was what was selected, but I kept seeing something about port 9100 and when I spoke with HP support, they said something about port 9100. Just randomly, I switched the port on the printer and RIP and sent a job and it's actually printing.
Thank you everyone for your help with this. Insane, that it is something that is so easily changed.
odd, 8080 is a webserver port
do you print to a company server that accepts jobs from remote users?
