What is I/C?Run Head Wash 2 times. Leave cartridges in I/C.
Ink Cartridge HolderWhat is I/C?
You do have the risk of the printer not working on return from several months. The printers are really only supposed to sit for maximum of two weeks. This is why you’re supposed to run the head wash two times.Ink Cartridge Holder
Do you have a link to the running a head wash process?You do have the risk of the printer not working on return from several months. The printers are really only supposed to sit for maximum of two weeks. This is why you’re supposed to run the head wash two times.
It is in the User Manual. You can download it from the Roland Download Center: https://downloadcenter.rolanddg.com/SP-540VSDo you have a link to the running a head wash process?
Appreciate it. Do I need 4 cleaning cartridges or can i do one head at a time B/C, then M/Y? Is it it ok to leave the cleaning solution in the lines during a period of storage? Pinch drainline and wetcap the machine after running? Or, is it better to follow some of the advice above? Is there a way to tell if the machine has been updated to run Max2 inks? We received it used and that is unknown- the cartridges currently in it are aftermarket and don't indicated.It is in the User Manual. You can download it from the Roland Download Center: https://downloadcenter.rolanddg.com/SP-540VS
You NEED 4. Roland SL-CL or get from the brand of ink you use or refillable cartridges.Appreciate it. Do I need 4 cleaning cartridges or can i do one head at a time B/C, then M/Y? Is it it ok to leave the cleaning solution in the lines during a period of storage? Pinch drainline and wetcap the machine after running? Or, is it better to follow some of the advice above? Is there a way to tell if the machine has been updated to run Max2 inks? We received it used and that is unknown- the cartridges currently in it are aftermarket and don't indicated.
Perfect. I appreciate your time.You NEED 4. Roland SL-CL or get from the brand of ink you use or refillable cartridges.
The Head Wash will empty the lines, although you can then pull from captop lines to fill lines, dampers, heads.
NO on Max2
Thanks! One last question: as Im searching for replacement cartridges and cleaning cartridges, do the BN20 cartridges fit the older models? I haven't been able to come to a concret answer on this.OP's printer is an SP-540V, not a VS. As others have suggested, do the head wash 2 times, but then clip off the 2 cap lines, fill the caps with cleaning solution, park the heads and unplug the printer, leaving the cleaning cartridges in the printer. This will clear the ink and also keep the heads from drying out. The head wash is on p. 97 of the attached user guide.
Although I can't comment on the compatibility, you'd want Eco-Sol Max Cleaning Cartridges. You should be able to get them from your local Roland Dealer.Thanks! One last question: as Im searching for replacement cartridges and cleaning cartridges, do the BN20 cartridges fit the older models? I haven't been able to come to a concret answer on this.
ThanksAlthough I can't comment on the compatibility, you'd want Eco-Sol Max Cleaning Cartridges. You should be able to get them from your local Roland Dealer.
