Fred do you mind elaborating.
cOrKinSA
I am intrigued by this so do you mind continuing further since it is now posted in the Premium section.
I price by the linear inch and setup jobs to best utilize the image height available. I use a multiple of the selling price of the vinyl plus the selling price of each color used. I differentiate between calendared vinyl, cast vinyl and specialty vinyls such as metallics, transluscents, reflectives etc. I charge the same for process or standard spot colors, 1.5 times for metallics and double for medals.
I am not willing to post actual pricing in the open forums and, if you so desire and choose to take out a subscription, will be happy to provide them in the premium subscription Sales, Marketing and Pricing forum.
Posted by Fred from this Thread.
Fred Weiss
Gerber Edge Pricing
The following are the definitions and pricing we have successfully used since 1998 for our Gerber Edge pricing. Our films offered are divided into eight pricing groups and our foils are divided into three groups. All pricing can then be calculated based on the parameters of the job and are based on a print nest that is 11.8" high and by the linear inch. A small amount of additional cut height is available if needed up to 12.5" of height.
Film Groups
  • Group 1 = Intermediate performance calendared vinyl
  • Group 2 = High performance cast vinyl
  • Group 3 = HP metallic vinyl, HP ControlTac, Gerber Label Stock, Holographix films, static cling film, Plastigraphix PVC-10
  • Group 4 = HP cast translucent vinyl and fluorescent films
  • Group 5 = LexEdge™ printable Lexan® film and GerberMag 15 mil magnetic sheet
  • Group 6 = 3M Scotchlite 280 reflective film, Gerber Vision perforated film, Gerber AutoMag 24 mil magnetic sheet
  • Group 7 = 3M ScotchCal Deluxe Silver
  • Group 8 = 3M ScotchCal luminous film
Foil Groups
  • Group A = Non-metallic spot colors, process colors, transparent colors, clear UV/AbrasionGuard overprint, Matte clear overprint
  • Group B = Metallic colors
  • Group C = Medal colors
Print-n-Cut Pricing
Wholesale price per linear inch x 11.8" height is for one Group A foil printed on the named group of vinyl or film, cutting, weeding, masking and trimming. Above average weeding or trimming is subject to an upcharge by quotation.
Group 1 = 62¢
Group 2 = 67¢
Group 3 = 76¢
Group 4 = 83¢
Group 5 = 90¢
Group 6 = 1.00
Group 7 = 1.20
Group 8 = 1.70
Each additional Group A foil - Add 20¢
Each Group B foil - Add 10¢ to Group A foil price
Each Group C foil - Add 20¢ to Group A foil price
Gaps between prints horizontally are not counted for pricing but should be allowed for in planning the vertical nest height. Edge bleeds, if needed, add .04" all around and are counted for pricing.
Per order volume discounts are given as follows:
$100 or more = Free UPS Ground shipping
$200 to $499 = 5%
$500 to $999 = 10%
$1,000 to $1,999 = 15%
$2,000 or more = 20%
Minimum price per print run = $15
Suggested markup to retail = 150% to 200%
Simple setup from ready to use files is included. More time consuming setup charges for jobs may be added by quotation.
Typical pricing calculation examples:
Example #1
500 2" x 3" oval decals, one spot color, group 2 vinyl, UV/AbrasionGuard, no mask, trim in vertical strips.
The vertical nest for a 2" x 3" decal is five units. Therefore, the entire nest will be 500/5 = 100, 100 x 3" = 300". There are two Group A foils needed to print the job on a Group 2 film..
The price per linear inch is 67¢ + 20¢ = 87¢
Price for job: 300" x 87¢ = $261.00
Volume discount on job: 261.00 x 5% = 13.05
Discounted price for job: 261.00 - 13.05 = $247.95
Price per decal: 247.95/500 = 50¢
Example #2
10 12" x 24" four color process with spot white base coat on clear static cling film. No mask, individual trim, print image height of 11.75".
Each print uses the entire nest height. Therefore the entire nest is 10 x 24" = 240". There are five Group A foils needed to print the job on a Group 3 film.
The price per linear inch is 76¢ + 80¢ = 1.56
Price for job: 240" x 1.56 = $374.40
Volume discount on job: 374.40 x 5% = 18.72
Discounted price for job: 374.40 - 18.72 = $355.68
Price per decal: 355.68/10 = $35.57
iSign
wow!
awesome system... inspiring to see some of the areas of this business where our costs are fixed, transformed into such a complete matrix of carefully calculated, profit based, pricing structure, easily available for a sales tool. I hope I can some day distill even half of my constant cost items into a similar level of pricing convenience.
cOrKinSA
wow!
My thoughts exactly. It amazes me how much you can learn from this site! Since I am hoping to start a new on pretty much everything I did before, maybe I should do something as detailed as this with the rest of my services.
Thank you fred!
ShawnLVESP
Nice price structure. I see it's for a gerber edge.
I use a similar structure where i will measure by the inch and convert to feet and price that. Thank goodness for excel. I don't have a printer just a cutter. Do you do the same for cut vinyl? I'd be interested to see that price structure.
thanks in advance
