I believe so, it's been awhile. I use goproduce, never used gosign as I only have the flatbed... But it should be the same?A few questions, I never used the back barcode because i was under the impression two cut files were needed to do that, one for each direction. But you are saying that the software "knows" which orientation the cut job is by the last number being a 0 or 5 ? Which software did that work in? GoSign, winplot?
We use cutter control to cut rolls as currently as GoSign won't sheet cut no matter how we try.
I could configure the code to do that though.
I have made a few changes to the one posted above, that adds the barcode number in text to the left, and defaults the barcode prompt # to the current date and time so you don't need to manually input the code and ensures it's always unique.
https://www.signs101.com/threads/summa-manual-barcodes.178680/. This is a long thread where a few of us were making it / discussing it. Post 30 of that thread has a bunch of SDKs that Christian posted, it helped a lot in understanding all the specific stuff needed to produce compliant codes that work front / back. It's good for a skim read!
