FREE Summa barcode Gen for Illustrator
Dale D
"If" and when you can make it more straight forward, or someone else comes up with a better one then Ill look at it. I wanted it to save time and be more efficient, and dealing with this is not efficient at this point. I dont have time to play on here as I have work to get done.
Dale D
My path was what Corel defaulted to so I dont know if Corel did it different for different versions of software.
sad_makaronchi
You have PE edition of Corel and name of reg folder is "CorelDRAW PE" that's why script don't find nesseary key and return "CorelDraw don't find". It's my mistake that i don't think that name folder in reg may be different.
Dale D
I guess Ill wait or look around because I manually added files and still cant get Corel to see it or work.
sad_makaronchi
Думаю, я подожду или поищу другие варианты, потому что я добавлял файлы вручную, но Corel всё равно их не видит и не работает.
I checked and i mistake again)) You need add also UserUI file:D 1770314317042.png
sad_makaronchi
Я исправил проблему с определением версии Corel Draw, а также некоторые неполадки в коде; это релизная версия 1.0.1 на GitHub.
