Gerber Egde New user
Hi all, I managed to make it print after buying and old computer with a paralell port. It worked straight away thanks all!
now I have too issues:
  1. first is the band that you can see in the prints? what can it be?
  2. I still have several white spots while printing. They appear randomly and I made sure that there was no dust...pretty frustrating
Thanks for the support
rrd
I have the exact same issue at the moment. I going to try a print server today. just not quite sure how to set the ip with the gerber.
Print on cast vinyl- white spots are usually from calendared vinyl. And use Gerber foils and 3M or 220 scotchcal vinyl.
Sorry what do you mean? I have discovered that indeed it only happens in my Imageperfect white Vinyl. in the transparent vinyl it works well.
rrd
Just got my edge 2 up and running today. Used and old print server to do it thru tcp-ip
Stephen Ford
To use your Gerber Edge 2, you need the software that supports the driver of your machine. The omega software is too expensive for such an old machine. I have another software with the supported driver from Gerber Edge 2 and compatible with Windows 10, 8, and 7. This software is not free but much cheaper than OMEGA.
Let me know if you are interested., Pm me.
Hi I have just got an edge fx with omega composer 1.56 but no dongle, what cn I do?
signage
I would recommend going with Omega software and since you are new you would need to buy the latest version. You would get the most help using it. but you could go with either CadLink Cut and Print for Thermal printer or Flexi but getting questions answered on this forum Omega would be your best bet.
