GR2-640 plotter Issues & how Roland want to repair it
heyskull
We purchased a VersaEXPRESS RF-640 printer & a CAMM-1 GR2-640 in November 2021.
The RF-640 printer has been amazing and prints as good as day one, with only general maintenance.
Sadly I cannot say the same about the GR2-640 plotter, from day one there have been issues with it.
Such as the blade does not lift high enough and scratched the media, It clunks and leaves marks in the media and worst of all it will not accept large complicated contour cut files.
I have been sending these issues over to Roland from day one but have now been told this is a firmware issue and after trying remotely install it they have said I will need an engineer to come out to install the firmware.
It is going to cost upwards of over $700 to fix (that is if it all it really needs)!!
Has anyone else on this forum had similar issues and installing the latest firmware has it fixed the faults.
netsol
when you go to the support site almost everyone has a list of FIXES for each update
while everything is not listed, it should give you a fair idea of if this type of issue has been addressed
heyskull
How do I access the support site and where are the FIXES?
CustomThunder6
Because these plotters are not made by Roland, just chinese standart factory where roland, summa, graphtech, uscutter and other's brands are buying them with applied brand sticker on it
heyskull
I have found the parameter record card/sticker on the underneath of the plotter.
But the AAS offset values are ripped off.
Can I just use the values in the machine?
I am always concerned with updating firmware on any machine or computer as I am concerned I brick the item.
Is this safe and will this rectify the issues with the machine? Or am I being given false hopes?
THanks
CustomThunder6
These offset values are givem to every Chinese made machine, if u change them - it's on your own of result it will give out
Jwei flatbed cutters are with offset values embedded on machine plate
Roland eu2-1000mf have too this plate but with different info for us because it's printer
CustomThunder6
You can adapt these values be yourself
If u need i can upload roland program and manual
No need for roland technician
If somebody took for THIS money
Took it BACK
