Okay so what you wanna do for the warping is go into your profile manager on your IPS
computer, and create a profile for your pvc. At the bottom of the main menu when you go into them, if you scroll to the bottom and click the advanced options, you have vaccum settings. Turn them up to the max which is like 1400. Leave your input tension at like 50-75 thats more than enough, but the curing, and heating vaccuum put at like 1400.
Them babies aren't gonna move at those settings. If you get crash warnings from that point, then there is something going on with the vacuums in general. (Or maybe the curing units. I know we technically have 2 faulty curing units that still get hot, but they don't get to their right temps so we have to becareful about what material goes through and how its being fed for said job.) Usually isnt a problem, but it absolutely is with Styrene. Which i hate printing on. Styrene is trash material.
Over the last year or so that I have been running the R2000+ we have, the more ive become familiar with the internal settings. My next move is to find one for magnet material, because we have an issue of the magnet material getting too hot and expanding, and when it cools its bowed on the edges and doesn't go back to original shape. Which makes contour cutting on our colex nearly impossible for accurate door magnets. Very annoying. So I feel your frustration.
We print PVC a lot, and you just have to clean them really really good. You cant see hand oils when cleaning so you cant leave any inch of those things un touched. And try a 90% alcohol rather than a 70.
Also when or if your PVC is coming with a cap sheet (often times they do) DO NOT remove it, until you're ready to print, and still clean that side.
Hopefully that helps.
