The replacement Feed Motor board fixed the problem. Since the signal was a pass-thru on the board it was easy to verify. The used replacement board works and printer is back to normal. In service mode on the Feed motor aging the motor now goes forward and back like the manual says, instead of just forward. When doing the Grit Encoder test the M-ENC value still goes 0-4000-8000-12000-16000-0, and the G-ENC matches it, then says "completed". Media advances normal and all good. I want to thank all involved especially Jim, DamonCA21, and Ewan for all suggestions and advice. Hopefully it helps others in the future since most I read about had no finish to the problem. Happy printing!
